Old 04-07-2016, 07:17 PM   #11
RSchleder's Avatar
Originally Posted by brookstone345sa View Post
The center part of cap is removable
Attachment 104212
Entire center cap piece can only be removed by taking off wheel
Thanks for taking time to check your center cap, I appreciate it. Guess I'll be looking for a center cap with a removable end section.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is online now   Reply With Quote
Old 04-07-2016, 07:25 PM   #12
RSchleder's Avatar
Originally Posted by tragusa3 View Post
FYI, "Buddy Bearings" DO NOT get grease to the inner bearing. Learned the hard way and got to see the evidence first hand as my wheel fell off the trailer.
If you have the Dexter axles with "EX-lube" grease fitting, that is a different story. Are you sure you have "Buddy Bearings"?
I have the EX-lub system and I've have found stainless steel center caps that have the removable end on e-trailer for $11 each! Thanks to all.
I'll be ordering these soon!!!
30 years RV'ing
11 different RV's
Old 04-07-2016, 07:38 PM   #13
Great! There are some good youtube videos showing exactly how they work. I went to my local trailer shop and they had a demo axle for me to see. Looked like it should work well.
Some guys on another forum say to still be very careful not to blow out the rear seals by pumping too hard. It's not good to get grease in your brakes. They say they would still hand pack, which I'm considering doing too.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is online now   Reply With Quote
Old 04-08-2016, 12:54 PM   #14
Some guy in back...
I bet those same guys only drive manual transmission vehicles, don't use cruise control and would NEVER touch a microwave oven!
ChateauV10
SF Bay Area
'99 Ford E350 V10
'16 Rockwood 8329SS
ChateauV10 is offline   Reply With Quote
Old 04-08-2016, 01:03 PM   #15
Who Dares, Wins
doc73's Avatar
Do you think they use the heat in the winter or add a layer of clothes ?
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 04-08-2016, 02:37 PM   #16
How often are you adding grease to the bearings? They are the same tapered roller bearings used in a car. The bearings on a car usually go 50,000 miles plus before needing to be cleaned and re-greased. If they are properly packed with grease during service there is no need to regularly add more grease.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 04-08-2016, 03:24 PM   #17
We installed wheel caps with removable centers on our cargo trailer. Purchased at E-Trailer. They work very well.
PenJoe is offline   Reply With Quote
Old 04-08-2016, 04:52 PM   #18
How often? The trailer we had a failure on was a brand new trailer. Beware of the factory grease job. Our inner bearings were dry as a bone.
Old 04-09-2016, 10:39 AM   #19
Learjet's Avatar
i see you never found a bad bearing on your first manual repack and grease leaking on your brakes. Yeah, that never happens on these axles.
You can be cute all you want with you opinion, but I've been there done that and will hand pack now.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 04-09-2016, 11:32 AM   #20
Canadian Member
itat's Avatar
I have the bearings repacked by hand every one or two years depending on mileage towed. I use the grease zerks in between manual repacks.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
