Old 10-31-2015, 10:16 AM   #21
Originally Posted by camperboy View Post
2015 model year. For this year they went to a taller bedroom a/c. They said the low profile unit was too loud
I have the standard height 13.5. I can't imagine the low profile being any louder. I have been told the 13.5 low profile Coleman is much quieter than the Dometic unit. If I had it to do over again I'd go low profile... height can get you in trouble. Just MHO.
grayfox is offline   Reply With Quote
Old 10-31-2015, 10:35 AM   #22
I am not sure what Columbus used for a low profile unit but my bedroom a/c is a Dometic Quiet Zone. It is quiet.
camperboy is offline   Reply With Quote
Old 10-31-2015, 10:45 AM   #23
Blog: RVroadtripper.com
hbillsmith's Avatar
If the Wildcat is 12'3" sitting level then how does adding a low profile a/c change your height by 15"? A low profile unit should be around 8 to 9" so you should be around 13' even.
Is your rig sitting nose high?
Brochure said "12' 6" but that was without the front low-profile A/C. I measured 13' 6" when attached. The 2015 GMC 2500 sits very high and at best I am nose high 1" to 2" depending on how I adjust my hitch height for bed rail clearance. I can go from 6" to 3" clearance. At 13' 6" that is with 6" clearance and the trailer almost 2" nose high.
On a long flat Interstate route, I'll run with 4" clearance, but to be safe I always look for bridge and overhang clearance of at least 13' 6".
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 10-31-2015, 12:29 PM   #24
Just a question is your Dometic Quiet zone connected to your duct work in the coach? I wish mine was. That would keep the noise level at a much lower level
Old 11-14-2015, 11:26 AM   #25
Yes in my Columbus 295 both units are tied to the same ductwork.
Old 11-14-2015, 11:50 AM   #26
TURBS's Avatar
You can take the baffle out
Old 02-07-2016, 02:24 PM   #27
As HBILLSMITH said., you better measure when hooked up and ready to go.
dmac1951 is offline   Reply With Quote
