10-30-2015, 03:55 PM
height of unit
specs say 12'3". I assume that is to top of the main ac unit?
If you add the second a/c how much taller does it get?
10-30-2015, 03:56 PM
High profile a/c is 13"
10-30-2015, 03:58 PM
I have a 12' 3" tall 5th wheel " highest point".
I'm installing a high profile a/c on it.
Will come in about 13' 4"
Thanks very much!
10-30-2015, 03:59 PM
Originally Posted by camperboy
Thanks very much!
What camper do u have?
10-30-2015, 04:00 PM
At the moment Columbus 295rl. I am going back to a 1/2 ton truck and need a smaller fiver. Wildcat is slightly heavy but has good features
10-30-2015, 04:01 PM
I have a columbus 320rs.
10-30-2015, 04:02 PM
So that 12' 3" height is the highest point of your columbus.
10-30-2015, 04:03 PM
I like my Columbus fine. Its just too heavy for a half ton truck, also a little longer than I need.
Your dimensions are for high profile bedroom units? A low profile shouldn't be more than 8 or 9"?
10-30-2015, 04:04 PM
I believe a lo pro is 4" shorter.
10-30-2015, 04:05 PM
No, my Columbus is 13'7 with the second a/c.
I was asking about the Wildcat which shows 12'3"
10-30-2015, 04:06 PM
What year is your columbus?
10-30-2015, 04:40 PM
Blog: RVroadtripper.com
My Wildcat with low profile front A/C is 13ft 6in. You should measure when connected to truck and airbags set for usual travel psi.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
10-30-2015, 05:11 PM
camperboy, you say that your current Columbus is too heavy for a 1/2 ton truck, and the Wildcat is slightly heavier than the Columbus. Am I missing something?
10-30-2015, 05:16 PM
I think he said Wildcat is slightly heavy for a half ton. Not heavier than a Columbus. Depending on the floor plan chosen, I agree with the half ton comment.
10-30-2015, 05:31 PM
Yep you are right. I had to read it several times before it sank in.
10-31-2015, 08:16 AM
2015 model year. For this year they went to a taller bedroom a/c. They said the low profile unit was too loud
10-31-2015, 08:18 AM
If the Wildcat is 12'3" sitting level then how does adding a low profile a/c change your height by 15"? A low profile unit should be around 8 to 9" so you should be around 13' even.
Is your rig sitting nose high?
10-31-2015, 09:45 AM
my 2015 Wildcat 317RL is listed at 12'6", with my optional low profile AC it is 13'4", I measured and confirmed such.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
10-31-2015, 09:52 AM
Gotcha. I as looking at the mid profile units.
