help..big problem
Hello, I found this forest river forum and hopefully this is the right place for this as i need some help.
I purchased a 2014 wildcat 327ck 5th wheel last summer here from my local dealer and they delivered it to me.it was awesome all summer,set up as a cottage more or less.when I went to close up for the end of season,the opposing slides came crashing together buckling a piece out of the floor and driving the l sofa back into the wall cracking it.It all happened so fast and I wasn’t expecting it.I had to slide over the kitchen counter ,hold up the sofa piece to allow the dinette side slide to go under it to get it together. My dealer suggested waiting till spring to fix, so I did and they have had it for a couple of weeks now.
My problem is that there doesn’t seem to be a solution for the dinette slide not crashing into the sofa. It is suppose to go under it,but won’t. they have now moved the wheels back,but the sofa now becomes a teeter totter. Not acceptable. The have repaired the wall and I haven’t checked the floor but assume that is ok to. I have looked at the 15 model and it looks like the l sofa is shorter on that side now in pictures I have seen? Is that true or just the picture image? Is there a problem and that is the solution as it seems very logical to me?
I’m hoping for some guidance or a solution,please help..thank-you for listening
