Old 01-12-2014, 10:30 AM   #1
Help Manual Override for Sliders 327CK
I'm sure it's been covered before sorry but I went to retract my sliders I got bedroom in 100% living/dinning side in 60% but kitchen nothing. I'm on 110V not the battery. I can't find the crank hole unless the hydraulic motor in the front bay is the drive unit. I don't know and the booklet tells me nothing. Any help will be welcomed. Thanks Chris
dona5779 is offline   Reply With Quote
Old 01-12-2014, 12:42 PM   #2
Hey Hey I figured it out. My manual override to the pump (1/4" hex) was behind a piece of plastic in the cargo bay. Inserted my drill and the rooms are coming back in. And I found out why they didn't work to begin with, one of the hoses was not tight enough and was leaking fluid, just and other in many "I had to fix" items. But all is well for now. Thanks for looking and this may help you in your 327CK adventure. Chris
Old 01-12-2014, 01:29 PM   #3
Now the rooms are in I started to look at my pump and it's fuses. Well I looked on the fuse panel in the kitchen area and 20A marked slider then 15A marked pump (thinking this is the water pump not hydraulic) but all the fuses are good including the one below (5A) the pump itself. I don't know where to look now. Any ideas please chime in, Thanks Chris.
Old 01-12-2014, 02:07 PM   #4
Campfire Master
The hydraulic pump pulls directly off the battery. There is a circuit breaker terminal block near the battery. The breaker should be a self resetting. Might take a few minutes. Make sure the battery is fully charged. As battery voltage drops, the amp draw of the motor increases. If it increases enough, the breaks will trip. I installed a jumper wire from a spare breaker to power the pump.
John
AVid is offline   Reply With Quote
Old 01-13-2014, 05:39 AM   #5
Turns out Dead Battery dated 4/13 nice. Camper has been on 110V since purchased, I thought it had a trickle charge mode, guess not. I'll have to find a dealer who will honor the warranty around here. Thanks for your help, Chris.
Old 01-13-2014, 06:19 AM   #6
You must be on a (Seasonal Site)? If used as a (Travel Trailer) you know if the battery is (Low or Dead) (jack,water pump,lights,slides) when you (Set-up) each time. Youroo!!
Old 01-13-2014, 06:21 AM   #7
Ford Idaho's Avatar
Dead before it's time.
Was it boiled dry?
Amazon.com: Battery Tender 021-0156 Battery Tender Plus 12V Battery Charger True Gel Cell Model: Automotive
Old 01-13-2014, 06:39 AM   #8
Campfire Master
Glad you got it sorted out. I have seen bad converters. Like Ford said, it may have boiled the battery dry. I do check the battery fluid level several times a year, and do end up adding a small amount of water from time to time.
John
manual, slide
