08-11-2014, 04:20 AM
#141
Originally Posted by BigJohnD
Lippert unfortunately is like many others. "That's the first we've heard of that problem". Never mind the forum, and the thousands of people we communicate with that own the products and have similar experiences. I've visited a huge amount of dealers across the US, and several manufacturers, and I always quiz them on issues like this. I've only got a few honest answers unfortunately. Just the dishonest world we live in.
With Lippert, if they put as much effort into getting it right as they do trying to get out of being responsible, then we might have something. I really admire those small handful of manufacturers that still fab their own frames.
Big John D , I disagree with your last paragraph, you are painting Lippert with a broad stroke. I just got back from the Rally. I was going to have them install a 4 point electric leveling system for $3200 00, When I got to the rally I went to their booth, talk with the head Creative Engineer. Started to talk to him. He said that I should go with the 6 pt. Level up instead. I said that I was afraid of my frame twisting. He said they would have to weld 2 beams across and add 36" long welded beam in the back of the read axle to hold the Hydraulic Ram. He said that it would be 10x's faster and stronger then the electric one. I said okay lets change the order being the show cost was 4200.00 installed. When I took the unit in they said being I'm 31' I only needed 4 pt. because the short distance would make the level up fight to get level. Said I had to be over 33' to get the 6 pt. to work right. They installed the 4 pt. and did all the welding required. When I went to pay my bill they added 400.00 for welding and charged me $4600.00. I went back to the head creative engineer and told him what happened. He called billing and had them refund me and my total bill was then $3400.00. He said a deal a deal and I should not have to to pay for 2 jacks I never got. Now I'm very pleased with the new system and probably have the strongest Rockwood Frame on the road. They kept there word and you have to talk to the right person. LCI takes up miles of buildings and employees more people then anyone in Elkhart County. My unit is now lighter GW then with the standard system that came with it. Each jack weights 12 lbs. but can pick up 7000 lbs.
The two front jacks on the old weighted over 40 lbs. each. I gave them to the OLD COOT. LCI may get a bad rap on this forum but they do keep there word and Know Their Stuff. I will post pictures of The system being I'm the first Rockwood to have it installed on. Also another tid bit of info for everyone, I learned they also have a plant in the Boston Mass area....
Coachmen M/H
Concord
2018 / 300 DSC
08-11-2014, 07:06 AM
#142
Go back and look at my first post. Lippert wouldn't work with me because I had changed to a fifth airborne hitch. Claimed it was a modification.
Glad when people get work done by lippert and FR. They should. If they are so good. Why heavier metal and more welding?
I will not buy another lippert. Think I can build my own cheaper and better. When I do pin weight will not be my concern.
08-11-2014, 04:39 PM
#143
Because the frames are lite weight. It's called a signature ulta lite. Yes the frames are lighter. It was good for me that they beefed up the frame so it wouldn't twist. That's why I took it to them not a dealer or CW. You pay for what you get both money wise and frame wise. There are only certain things that can be done without straightening the frame. Sorry about your problems, hope you get it resolved. When lippert puts it on they now own it. No arguments they did it not me or a dealer. They modified it not me. Glad you didn't get hurt or your family. Just letting you know what happened to me. I was also answering John saying Lippert did mine right. Also members who are putting electric systems in after market could have a problem let's hope they don't.
Coachmen M/H
Concord
2018 / 300 DSC
08-11-2014, 07:09 PM
#144
Plain Old Member
Not denying they can be of help, IF you can get the right person on the right day. Like any company, they're are some good people, and some bad. The proof is in the posts industry wide about their frames, and the denial of fixing. Being somewhat like arpipeliner, I've seen better steel and welds in a high school ag shop. Do I think my camper is worth the $54k I paid for it, absolutely not. Set that 15.5k frame next to my 14k gooseneck frame. I-beam for I-beam, weld for weld, and tell me lippert makes a good frame. Your story might be quite different if your pin box frame cracked and just about came off the truck like some have. I'm glad yours is in good shape and they got you fixed up. If mine cracks, they won't touch it. I'll do my own fabrication.
Sent by ME
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
08-12-2014, 02:22 PM
#145
Sent by ME
Very good point big John, but this is the third (3) 2007 with the same problem. Something happened that year. It's the only year that I have saw on this forum. My Rockwood has a stronger beam and pinbox area I have the the pictures of the frame that I took at the factory, Even through this can't help people who have a 2007 maybe it did help us all down the line with new frame development. But I still feel bad for the OP problems. I also have faith in Lippert and Forest River. When you lose hope you sell your unit and I would bet he wouldn't buy a FR product, even through they all have problems.
Coachmen M/H
Concord
2018 / 300 DSC
08-12-2014, 03:42 PM
#146
WOW...I started reading this string and could not stop. I actually got goose bumps!
First, I am so sorry for you folks who have had this failure and glad no one has been hurt so far.
Second, I'm curious, legal actions have been mentioned a couple of times here, but has anyone actually discussed this with an attorney? Curious as to their take on all this. IMO, the folks who are having "official Lippert" conversations with you are constrained by what/how they can respond to you no doubt by their own legal department. We all know they are not dumb nor clueless. They are aware of this type of failure but legal would never let them admit to it unless the Lippert Corp put out a major recall. That's how the corporation I work for does it and most others too.
Third, as soon as I get up from my desk this afternoon, I'm taking my inspection camera out to our Sandpiper with a Lippert frame and see what I can see.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
08-12-2014, 04:03 PM
#147
Unless your frame is stamped ALL OVER "made in the "USA" I wouldn't tow a dung beatle behind it. Period.
A "fabricated" I beam used on "lite" and ultra lite trailers is basically sheet metal welded to form an I .
TURBS
"SABRE OWNERS UNITED"
08-12-2014, 08:54 PM
#148
DW's 401(k) Plan
Like Kerrlakelover, I too, read this from the beginning. It wasn't until I saw this piece "....third (3) 2007 with the same problem..." that something FINALLY hit home. My wife's uncle, God rest his soul, had a 5th wheel - no, I don't know what make, but it had to be around a 2007 - and it completely buckled at the angle behind the pin. Not aware of the technical names of the different parts of a 5th wheel. This happened in his driveway as he was backing the trailer. Trailer dropped down on his TV and did some major damage on the back of the truck. Insurance Co ultimately totaled out the trailer and fixed the truck. Sure wish the wife's uncle was still around to get more info. But, reading all the posts here, it sure sounds like he had the same problem.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
08-12-2014, 09:06 PM
#149
Plain Old Member
If I didn't know anything about steel, welds and structure, I probably wouldn't get so aggravated looking at the frames. Turbs is spot on with the way a LOT are made. Not all, but a LOT. On a floating oil rig, every critical structural weld gets x-rayed or mag tested at various times. It is a grueling process. Everything added that will be load bearing is mag tested or x-rayed. Of course we're dealing with 20-30,000 tons of floating steel the size of a couple of football fields that gets beat to death and flexes a LOT. So, I do know you can have a pretty weld fail, and a crappy weld pass. But, when you can look at a frame weld and can tell it was a cold weld with minimal to no penetration into the steel, it's not a good sign. Just a matter of time before a failure.
I have a tad of faith in ours. It's been towed around 5000 miles on some pretty bad roads, and I haven't seen any signs of failure yet.
08-13-2014, 12:01 AM
#150
2007 WildCat 32QBBS
BigJohnD- The point I tried to make was the fact that Lippert used the wrong material for the job. The 6x2 tubing used had a wall thickness almost half of the pinbox side plate mounts. The tubing itself sheered. Maybe 2007 was the only year they made this mistake, but they should own up to it and make it right instead of the jerking around and lying they did to me.
Also all, don't think for a second there are only a few of us this happened to. There are many this happened to in other Wildcat forums and the like. Early detection is tough. Even with a bore scope I couldn't tell the severity of it until I took the fascia down. An on sight repair for this could be $6000. Luckily I'm a fabricator/mechanic and repaired and replaced it myself.
Sent from my KFJWI using Tapatalk
08-13-2014, 07:20 AM
#151
Plain Old Member
Hopefully issue was isolated to 2007. Of course the issue wasn't just wildcat and there were several other brands of various years with the same issue. I find it interesting wildcat swapped to the BAL frames. I looked at one a little closer the other day. Definitely a little different. I had looked at a schematic of that frame before you really started seeing them on the lots, and all I could think was, finally, somebody is breaking the mold. Time will tell, and I hope its a good thing.
Sent by ME
08-13-2014, 02:59 PM
#152
Reading about frame failures sure gets one to rethinking "Ultralite" models. We know why a receiver hitch or bike rack on the back of the ultralite is not a good idea but most, myself included don't give the hitch pin area a thought. I went out to where our RV is stored today and took a good look at the hitch pin area on our 2014 8289WS, can't see much of anything beyond where the revolution bolts up to the RV, (4 bolts) that I could see. What I did was to level the RV front to back. Next I checked the level of the frame that the revolution is bolted to, that was dead level with the rest of the trailer. My theory is as long as that area remains square with the rest of the RV things beyond the hitch pin area that cannot be see are "probably" ok. If that frame that the revolution bolts to even becomes slightly off then there IS a big problem. The RV Must be dead level front to back to check this. I would think one could check the side to side also but an adapter would need to be fabricated, also the RV would need to be dead level side to side.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
08-13-2014, 03:10 PM
#153
Preslely01, Here some pictures of your frame. I wouldn't worry if I were you. Also your pin box is frame in with the same material or beams as the sides in the pictures.
Coachmen M/H
Concord
2018 / 300 DSC
08-13-2014, 03:42 PM
#154
I am not worried now and I can load even more stuff under the bed . Only thing now other than clothes is a ladder for slide maintenance on the road should the need arise.
That is a pretty beefy frame, with the revolution you need that much as it places more stress on the frame than a standard pin box does.
Brian
B and B
08-13-2014, 04:21 PM
#155
Brian
Your right, The pin box is framed in only 10" wide with a cross beam in front and behind to make the box for the Revolution. That is why we can't just put any pin box in without doing some frame mods. to make it fit. IF you look at the wildcat problem it is pretty easy to see the difference in the metal and full welds. Might not be the best welding job I have seen but it looks like they have advanced and think IMO that lippert is always getting the short end of everything. I'm still sorry for the OP'S problem, but lets just not blow this out of proportion and freak everyone out is my point. By the way I don't think that my wife can load anymore under that bed. I'm going to hit the scales once again on the way home and compare what I had to what I have now before the auto level system they installed. that frame also is the same for Flagstaff ultra lights. If you have questions on your frame here is the person to talk to: Bob Tiedge Creative Engineer @ LCI # 574-312-6308, email bobt@lci1.com. hope this helps everyone... ...
Coachmen M/H
Concord
2018 / 300 DSC
08-13-2014, 06:48 PM
#156
Many thanks for those pictures, puts my mind at ease and allot of others too I hope. That `07 Wildcat was in horrible shape, I hope the OP got back every dime he was out to fix it.
Joe & Beverly
2014 8289WS lifted
08-25-2014, 07:04 PM
#157
We had a 2007 Forest River Wildcat 5th Wheel 28 ft. WE were completing our cross country trip that we started in Florida. we were in California and as we were coming off the highway, we heard a strange clanging sound. There happened to be a Camping World near where we were and so we pulled in. When the mechanic looked at the fifth wheel, he noticed that the hitch was only an inch or two from the bed of the truck. Upon further investigation, the frame of the the pin hitch was cracked in a number of spots and that was what you could actually see without taking off the front of the unit. The insurance company came out and totaled it. We then had to pack all of our things in a u-haul and tow that back to Florida. When we got everything out, we could see that our closet was completely buckled and pushed up from the pin hitch. We were lucky that this did not happen when we were going 60-65 mph.
08-25-2014, 07:47 PM
#158
We owned a 2004 Crossroads Cruiser and this exact thing happened to us. The whole thing is very dangerous. We had owned our unit for about 6 years when it happened to us. After a lot of talk and advise and help from the Crossroads manufacturer, our rv was repaired.( Lippert the maker of the part, and Crossroads shared the cost.)We were so very grateful to them for taking such good care of us and standing behind their product.
08-25-2014, 11:02 PM
#159
OP here!
Wow! I had no idea this thread was still going! Thanks to one of you sending me a PM and letting me know I am back to finish the story, well the little there is to tell.
So...Lippert fixed the frame for free but we ate the cost ($3300) of taking the cap off, fixing the buckled floor, and putting everything back together. Despite numerous attempts at trying to get Forest River to cover those costs we just gave up.
We haven't had any more issues with it and we actually just pulled it home from a wonderfully uneventful 2 month stay down the shore.
08-25-2014, 11:17 PM
#160
I was worried you wouldn't reply glad everything is ok, and you are well. Did your husband finally learn how to operate the camera? J/k!!!
