Old 06-21-2015, 01:12 PM   #11
kg4gfv's Avatar
Originally Posted by Having A Ball View Post
No never. What are those ?
Ok never mind then. My TT has a ratcheting bar that is placed on the top on the slide and locks the slides during transport. I thought if they are in use on your application that maybe they had been place on to tight or had bound during transport. Not the case then here. Sorry about your problem. Happy camping.
kg4gfv is offline   Reply With Quote
Old 06-21-2015, 01:14 PM   #12
Having A Ball's Avatar
Gotchya, thanks
Having A Ball is offline   Reply With Quote
Old 06-21-2015, 01:17 PM   #13
Originally Posted by Garret Anglin View Post
Get this looked at PDQ. I have a Cross Vthat had a very similar BUMP inside and out. I contacted FR about what I discovered and they authorized repair. What was found the header beam across the top of the bumpout cutout was supposed to be welded...it was not, never had been, and was flexing its way into a total failure of the panel from the cutout to the roof. I took it to a local auto body/Marine shop and they discovered the manufacturing oversight...$1500 repair. You also may wish to reinspect the same location in the interior...mine had it also but was difficult to see. Good luck!
Thanks for the heads up! I'm out all this week then I'll take it to the shop next week.
What you explained seems like the culprit.
Seems like a dumb thing to NOT do (weld it in) when it's probably the weakest point with a slide that big.
Old 06-21-2015, 01:22 PM   #14
It looks like the luan backer had gotten wet and delaminates. With the slide out in the open position look at the molding or seal directly under the crease. Inspect it for small area that would allow water penetration. Too late to do anything to the wall, but sealing the area of penetration will stop more damage. Since the wall is laminated you can't repair from inside.
hillsdaletc is offline   Reply With Quote
Old 06-21-2015, 07:16 PM   #15
Ok, when I set up tonight I will check.
Are you referring to the underside of the wall where the rubber "seal" lays between the wall of the unit and the actual slide?
Old 07-08-2015, 11:13 AM   #16
I checked the area and it all seems to be intact. From what I could feel, there is no gap.
I do believe it's the header beam as described, thanks for the info.
I have been talking to Terry Milarczyk@ Forest River and he advised this is not "normal"
and has made arrangements for my unit to be transported to the factory for inspection and repairs!
Terry has been more than accommodating and very helpful with both this issue and my fading cap repair that was just completed!
I was really worried about forest river not taking care of us but Mr.Milarczyk has been awesome and knows great customer service!
Terry has made arrangements to pick our unit up and transport back to the factory to have needed repairs completed. He called it a "good will repair"🏻
Thank you for everyone's input and advice. I will be posting the out come once they inspect it.
Again hats off to Forest River for their outstanding customers service and having a guy like Terry Milarczyk on their team
