Old 08-19-2016, 08:10 PM   #11
Blog: RVroadtripper.com
hbillsmith's Avatar
Originally Posted by Wheels Down View Post
I have a 2016 F250 6.2 3.73 SB CC Lariat, my TT is a Flagstaff 27BEWS Ultra Lite.
I am considering some air bags for my TV, so I am looking over the fence at this thread for some info. Sometimes a bad spot on the highway can send a jolt all the way through the cab and up my spine when towing. So air bags may be the ticket for a smoother ride.
The only concern that I have is that some post on the subject suggest that the air bags cancel out the automatic anti-sway controls (with competing motion offered by the air bags, I guess?)
Anybody know the real reason and if it is true?
I don't think you will see any benefit from airbags on a 250 pulling an ultrahigh TT. With a heavy fifth wheel, maybe. I'm not sure you even need a wdh, sway control though yes
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 08-19-2016, 08:19 PM   #12
northstar1960's Avatar
Originally Posted by aceinspp View Post
In installed Timbrens and towing a 9000 # tt loaded with equalizer wdh works great. No sag Timbrens also control bounce and sway . Later RJD
Timbrens control bounce AND sway . news to me . didn't think they could even improve a ride let a lone help with sway .
northstar1960 is offline   Reply With Quote
Old 08-19-2016, 09:09 PM   #13
hbillsmith,
I have the heavy Equalizer WDH and that helps a lot with sway.
The trailer weighs around 7800# loaded. I know I am well within limits for payload,tongue weight and TT for this TV.
Just looking for something to take the sting out of some nasty sections of highway. Thought air bags maybe the answer. If not what is, more pillows?
Thanks,RMc
Wheels Down is offline   Reply With Quote
Old 08-20-2016, 01:42 PM   #14
No psi will be right for everyone. Add air til bed rails are level.
JR Smith is offline   Reply With Quote
Old 08-20-2016, 09:32 PM   #15
hicksie's Avatar
I have an F-250 towing a 40 ft Crusader I keep my air bags at 20 psi and they haven't bottomed out the suspension yet When empty I run around 10+15 psi
Les Hicks
Canadian Army,Commercial Motor Vehicle Enforcement,
Supervisor Courts Services (Retired)
Living the dream with Carol my best friend/Wife for 50+ years2011 F-250 6.2ltr 2 WD ext cab / 2015 Crusader 350 touring edition
hicksie is offline   Reply With Quote
Old 08-21-2016, 10:50 AM   #16
Jim34RL's Avatar
What I did to determine my proper air pressure for my air bags, is as follows. Place truck on a level surface without a load in the truck or camper attached. Measure bumper height from road surface, in my case top of bumper; save this dimension. Now attach the camper to the truck and add air to the airbags up to this measurement. This is about how much air pressure you will need in the airbags to level your truck. You may want to +/- this air pressure by 5 or 10 PSI to improve ride when loaded.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, 100K+miles
Old 08-22-2016, 11:38 AM   #17
I had to play with it for a while to get the best ride with the least amount of bounce. I have a 2500 Dodge short bed,pull a 28' Grey Wolf, with a 3000 Honda Gen mounted on the tongue of the TT and about 300lbs of gear in the bed of my pick-up. I found the best ride for me is 12lbs of air. If I load 800lbs of motorcycle I raise it to 16lbs.
Las Cruces is offline   Reply With Quote
Old 08-22-2016, 08:09 PM   #18
muddyrode's Avatar
when i had my 2500HD i had bigwig air bags pulling a wildcat at 1900 pin weight also, i put 15 to 18 psi when pulling to stable up the rear and that would lift it off the overloads, and it helped a lot with the cross wind roll also,
drop down to 5 psi when not towing
2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
Remember slow and steady wins the race
muddyrode is offline   Reply With Quote
Old 08-22-2016, 08:13 PM   #19
CaptnJohn's Avatar
My 2016 F250 did not sag even though the pin weight put it very near max payload. The bed only dropped 3/4" with 2100# pin dropped in.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-22-2016, 08:15 PM   #20
I hadn't planned on adding bags, the truck squat some with the load but looked level and drove okay.
However, I weighed the trailer and found 600lb difference between front and rear axles, with the front being the heaviest. The trailer was sitting a little nose down and I was able to raise my hitch two holes to compensate to even out the difference between the two axles.
A trip to the scales to see if there's a difference in axle weights.
A fully loaded truck and trailer may require more air than empty.
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
