Old 08-23-2016, 04:42 PM   #21
The installation paper for mine stated the bags supports 50 pounds per pound of pressure. So I keep mine at 12 pounds to take 600 pounds of the spring and still have some springs and shocks actions.
Quiroule is offline   Reply With Quote
Old 08-23-2016, 04:53 PM   #22
TURBS's Avatar
Are guys quoting pressures before the trailer is hooked up?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "32"
Old 08-23-2016, 06:57 PM   #23
Blog: RVroadtripper.com
hbillsmith's Avatar
Both.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover
Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball
LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote
6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard
Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 08-23-2016, 10:52 PM   #24
No this pressure is hooked up, loaded and ready to roll.
Las Cruces is offline   Reply With Quote
Old 08-24-2016, 07:10 AM   #25
TURBS's Avatar
Hey 3/4ton drivers: What's your airbag PSI?
Then I'm between 50 - 70 psi 2200# pin
Haven't looked to see what un hitched psi is.
2015 Columbus 320RS
2008 2500HD Duramax
Old 08-24-2016, 07:34 AM   #26
jtstromsburg's Avatar
I have a different truck now and don't run bags, but when I had my F250 CC V10 4x4 and my Saber 34TBOK with approx 2500lb pin weight, I ran about 55psi loaded. Had them as high as 60 and as low as 30 while towing. Empty I'd shoot for 10-12psi.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-15-2016, 08:04 AM   #27
RwWildcat327re
I have the 2007.5 Dodge 2500 with Air Lift bags pulling a Wildcat 327re with about 1600 pound tongue weight unloaded. I have played around with the pressure a little and I have found that about 28 to 30 pounds gives me the best ride on rough roads. I leave it around 10 unloaded.
rickndebi is offline   Reply With Quote
Old 10-15-2016, 02:08 PM   #28
Salt Shaker's Avatar
2014 ram 2500, Firestone bags, 5-10 unloaded, 10 when loaded is level, i run 20-50 depending on road conditions.
Salt
Salt Shaker is offline   Reply With Quote
Old 10-15-2016, 02:30 PM   #29
Not a 3/4T, but 15# empty and 50#-60# with 5er depending on road. Have gone as high as 75# once or twice.
Old 10-23-2016, 08:31 AM   #30
RwWildcat327re
2007.5 Ram 2500...Airlift bags on rear. Wildcat 327RE...I run 10 psi empty and 28 to 30 loaded just to soften the ride. Really makes a difference.
