Old 08-19-2016, 01:41 PM   #1
Blog: RVroadtripper.com
hbillsmith's Avatar
Hey 3/4ton drivers: What's your airbag PSI?
My TV is 2015 2500HD GMC that I installed Firestone Airbags on in prep for towing my Wildcat's 1900# pin weight. What I've learned is I probably didn't even need the airbags. The 2500HD is plenty capable without them...but I have them now.
When towing I'll keep them at a minimum 10 to 20 psi until I hit a stretch of bad highway (think Shreveport I-20). Then I'll use the wireless compressor and pump them up to about 40psi (seems to help). But is that enough?
I've seen messages over time where others talk about running their bags at 50,60 even 90 or 100 psi. Granted some of these have heavier pin weights, some have put them on 1/2 tons trying to handle greater pin weights.
What I'm interested in with this posting is to hear from the 3/4ton drivers that like me have airbags. What's your psi?
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 08-19-2016, 02:55 PM   #2
brookstone345sa's Avatar
I run mine at about 40-50 lbs. Pin weight about 2200
brookstone345sa is offline   Reply With Quote
Old 08-19-2016, 03:34 PM   #3
I have a Wildcat 327 ck and I tow it with an 2011
F250, CC, longbed, diesel and I don't have airbags.
I have no sag.
whj77372 is offline   Reply With Quote
Old 08-19-2016, 04:34 PM   #4
PhoneDude 8289's Avatar
I have a 8289WS. No airbags, no sag. Truck and RV are close to level after a 3" lift on the RV. Previous truck was a Tundra with Firestone airbags @ 30psi with the same RV.
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 08-19-2016, 04:56 PM   #5
hbillsmith
what is the payload capacity of your 3/4T?
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 08-19-2016, 05:32 PM   #6
Empty bags are at 5, towing 20-25.
USMC2010 is offline   Reply With Quote
Old 08-19-2016, 06:01 PM   #7
See my sig...I run 15-20 psi towing. In fact, I just leave it there since I only drive 2 miles round trip to work each day. I played around a lot with pressures and actually found that anything over 20 had a detrimental effect on towing comfort.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 08-19-2016, 06:25 PM   #8
Georgia Frog Rally 2017
aceinspp's Avatar
In installed Timbrens and towing a 9000 # tt loaded with equalizer wdh works great. No sag Timbrens also control bounce and sway . Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-19-2016, 06:37 PM   #9
hbillsmith's Avatar
Originally Posted by wbdvt View Post
hbillsmith
Truck sticker is 2,515# but I've CAT scaled it and with passengers, fuel and a generator in the bed I'm only left with 1,997# available for pin weight. According to my latest CAT I'm using 1,905# of that. Now I leave the 85# genny at home unless I'm heading out to dry camp.
Old 08-19-2016, 06:46 PM   #10
I have a 2016 F250 6.2 3.73 SB CC Lariat, my TT is a Flagstaff 27BEWS Ultra Lite.
I am considering some air bags for my TV, so I am looking over the fence at this thread for some info. Sometimes a bad spot on the highway can send a jolt all the way through the cab and up my spine when towing. So air bags may be the ticket for a smoother ride.
The only concern that I have is that some post on the subject suggest that the air bags cancel out the automatic anti-sway controls (with competing motion offered by the air bags, I guess?)
Anybody know the real reason and if it is true?
Wheels Down is offline   Reply With Quote
