Old 01-17-2019, 12:16 PM   #1
Holding tanks
I just donít know why they put the galley vent under the Kitchen sink. Should be outside. Dumbo engineering
MichaelW is offline   Reply With Quote
Old 01-17-2019, 12:28 PM   #2
Are you sure you are not referring to an Air Admittance Valve? This is not a vent to the outside but an inlet for air.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 01-17-2019, 12:34 PM   #3
We have admittance vents on all sinks in our house since it was modularly built. Saves on plumbing work once the house was set on the foundation. They are commonly used in mobile homes. They allow for proper flow without any outside vent needed. Basically allows for less material and time during construction. I can see their advantages for RVs
2019 Hemisphere 272RL
2007 Silverado 2500HD 6L
Cabinfever97 is offline   Reply With Quote
Old 01-17-2019, 01:17 PM   #4
Are you having an issue?
These air admittance valves are used in thousands of R/V and modular homes and capably do the job they are intended for.
What is the issue that makes you say they are Dumbo Engineered?
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 01-17-2019, 01:40 PM   #5
Well when weíre camping it sure stinks underneath the sink
Old 01-17-2019, 01:47 PM   #6
That is the symptom when one goes bad. It let's air and odors out. Simple to replace.
Old 01-17-2019, 01:49 PM   #7
Head Rambler
Most likely the AAV (Air Admittance Valve) is stuck open. It happens. They're pretty easy to replace and most home improvement stores have them as well as that big online retailer! (You know, the one with the happy boxes!)
Gotta go campin!
Old 01-17-2019, 02:14 PM   #8
Like others have said the valve is not operating correctly if you are getting any foul smell. You may want to try spraying some WD 40 on it to clean it. Might get lucky and not need to replace.
Old 01-17-2019, 03:14 PM   #9
I replaced it. Thank you all 🤞
Old 01-17-2019, 03:16 PM   #10
Thanks for reporting back.
We'll assume it corrected the issue?
tank
