I found the valves for our Wildcat by locating the WH On the outside first then landmarked the thing to the left and right of it. Left tank central, i.e., where the drain valves are. To the right, refer vents.
I went inside, found the refer, to it's right was steps. I looked very carefully, then with a small Phillips screwdriver, removed the four screws from an approx. 12" X 12" door behind which were the three valves just as pictured.
