04-23-2017, 08:12 PM
How much height does a 2nd A/C add?
For example, every 2017 Wildcat 29RKP is listed as 12'3", but is that to the roof, or to the top of the standard roof air unit, or to the top of the optional 2nd A/C in the bedroom?
04-24-2017, 08:13 PM
It is to the highest point of the trailer not the ac as mine was listed as 11' 11" and the top of ac is 12' 4".... Found this out the hard way trying to put it into a 12' 2" opening on carport!!!!!!!
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
04-25-2017, 12:07 AM
I was afraid that might be the case. Thanks!
04-25-2017, 04:10 AM
Do NOT trust what they say it is. The best way is to take a level to the highest point on your roof and measure it there from the ground to the level. Most of the time a Maxx air vent or a A/C will be the highest point. I think they use the roof line only....
Coachmen M/H
Concord
2018 / 300 DSC
04-25-2017, 02:06 PM
My second A/C unit is the more compact type so it makes the fiver no higher as it and the A/C unit that came with it are at the same height.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
04-25-2017, 02:10 PM
As the eyeball measurement goes on mine it's about a foot, but it's angled and sticking out like a sore thumb, but it's there when I need it... and it's not a Dometic.
2017 Puma 297RLSS
04-25-2017, 03:54 PM
I hope you didn't take that measurement from the specs? The only way is to measure from the highest point on the roof. I know my A/C from the factory is lower then the Maxx air vent I put in....
Coachmen M/H
Concord
2018 / 300 DSC
04-25-2017, 03:58 PM
Blog: RVroadtripper.com
Web site said a 295rsx was 12'6" before optional front A/C. Added the low-profile front A/C and when I got it home it measured 13'6" to the top of that A/C which is the highest point. I carry a laser tape measure with me when I travel just in case I need to get fuel at a covered pump and I can't tell the clearance. A couple of times I also used it to measure tree limb clearance at a camp site.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
04-25-2017, 04:18 PM
Thanks for the replies y'all!
04-25-2017, 05:03 PM
You are so correct, do NOT TRUST Fr measurements....
Coachmen M/H
Concord
2018 / 300 DSC
04-25-2017, 06:13 PM
When you measure, make sure it is hooked up to the truck...that can make a difference.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
