Old 11-08-2017, 03:17 PM   #1
Identify Switch
Hope some one can help figure out this switch. Dealer didn't know and calling FR got me transferred 3 times and ended up on someone's answering machine.
We have 2 light switches 1 controls the led awning strip
The second one no idea
We have no scare light outside, no light under the stairs and we have a separate master switch for lights.
We even turn all the lights out at night time and flipped it .....nothing
Model is a 2017 256bhx wildcat maxx lite
https://ibb.co/cGcFYG
BoxPunch is offline   Reply With Quote
Old 11-08-2017, 03:20 PM   #2
MNtraveler's Avatar
Is there an outside light on the port or driver's side? We have an extra switch for that on the main panel (motorhome).
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 11-08-2017, 03:21 PM   #3
aside from running lights, I can not find any other lights anywhere
Old 11-08-2017, 03:28 PM   #4
Light switch?
2004 FR Sandpiper: I have 2 switches inside the door also. One operates the outside light under the awning. The other operates the ceiling light inside the door, but that light ALSO turns on/off by the switch on the light itself. If the switch is off on the light's body, the switch by the door does nothing. Maybe you have the same situation.
suzea is offline   Reply With Quote
Old 11-08-2017, 03:33 PM   #5
no light above the door
Old 01-10-2018, 04:28 PM   #6
Factory Representative
Wildcat Steve's Avatar
Thanks for the post and sorry it took me so long to respond. This is Wildcat Steve and I hope I can help. Are you able to take a picture of the switches and post them for me? I am taking a guess, but I bet that second switch, that doesn't seem to go to anything, is turning on your 12 Volt Tank Heaters. A picture will help me identify it accurately though.
Thanks,
Wildcat Steve
Wildcat Steve is offline   Reply With Quote
Old 01-10-2018, 04:44 PM   #7
A link to this photo was in the original post.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 01-10-2018, 05:03 PM   #8
Hi Steve
Picture is posted in comments. There is a smaller panel to the right with two tank heater switches.
I even showed the dealer and he had no idea lol
Old 01-10-2018, 05:16 PM   #9
Maybe hitch lights on the front? No idea.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 01-10-2018, 05:30 PM   #10
How are you turning on the interior living room lights? That switch should turn on and off the living room lights. Leave the lights on at the light itself and you can use that switch from now on. Hopefully that works.
Thanks,
Wildcat Steve
Old 01-10-2018, 07:43 PM   #11
We have a separate light switch for main lights lol I'll take a fuller pic in a bit
Old 01-10-2018, 07:54 PM   #12
SecretSquirrel's Avatar
Before I went chasing any further I'd pull the screws out of that panel, tilt it out and make sure it has wires connected to that switch. Manufacturers use these panels across a range of models. That switch might not be connected to anything in yours.
Crusader 337QBH
2019 F350 6.7L DRW CC LB 4x4 Lariat
B&W Companion 20K for OEM pucks.
SecretSquirrel is offline   Reply With Quote
Old 01-10-2018, 07:56 PM   #13
Mr. Dan's Avatar
X2
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 01-10-2018, 08:59 PM   #14
https://ibb.co/c3zvwm
New pic and good point about the switch not connected to anything
Old 02-08-2018, 11:42 PM   #15
MNtraveler's Avatar
Where are your kitchen/DR/LR light switches?
Old 02-19-2018, 12:30 PM   #16
You may have the solution by now. If so, you might want to post it to help the next person with the same problem.
Just in case... Our Wildcat has a light under and behind the steps. It was burned out. I discovered it when I was checking all for sizes, etc.
As a teacher my signature was, “If you think education is expensive, try ignorance.”
As a novice Glamper, it still applies.
RobertDS is offline   Reply With Quote
Old 04-02-2018, 06:36 PM   #17
Good afternoon,
If the switch illuminates when you turn it on, and nothing else turns on, that switch should be turning on the electric tank heaters.
Thanks,
Wildcat Steve
Old 04-22-2018, 06:14 PM   #18
I have the same issue. If I turn the lights on at the light the switch on the panel does nothing. 2017 Vibe Extreme Lite
Dclarke is offline   Reply With Quote
Old 04-22-2018, 06:16 PM   #19
I have the same problem. The switch on the panel does nothing. I thought it was for the overhead lights as you suggest but I have to turn them on and off at the individual light
Old 04-23-2018, 07:45 AM   #20
My light switch used to turn all the lights on and off but suddenly does nothing now. Brand new 2018 Vibe 288rls.
bcj245 is offline   Reply With Quote
switch
