Old 04-10-2014, 02:11 AM   #1
JAYCO Representative
Wildcat Chris's Avatar
Exclamation Importance of R-Values on RVs?
I'm interested in feedback on the importance of R-values on RVs…
How much did and/or does the stated R-value influence your buying decision when you purchased your current camper? What are the R-values of your walls / floor / roof / etc.? What is your expectation of any RV manufacturer or brand in terms of R-values or insulation properties?
Do you consider your RV to be 4 season or all weather? Why?
Did you also research or purchase dual pane or "thermopane" windows? Opinions on these windows?
What about 12V heated tank warmers or any other "4 season" or "polar package" add ons?
Does your current RV or camper you're interested in have radiant barrier or "astro foil" insulation? What is the stated R-value of that insulation?
Thank you in advance for your responses! Very interested to hear what people here have to say!
Wildcat Chris is offline   Reply With Quote
Old 04-10-2014, 08:06 AM   #2
Our 5th wheel has alot of windows so we ordered it with dual pane windows. They really do help when running the furnace in spring/fall and the AC in the hot humid summer. If the radiant/foil barrier was available we would've gotten that too. Our 1st consideration was floorplan.
Old 04-10-2014, 08:18 AM   #3
camper1999's Avatar
Ours has R38 in the roof and under belly and R9 in the walls. I have mostly bought trailers with this R rating and it really helps weather it is cold out or hot. I only have one A/c unit and never had a problem in the summer. During cold weather camping the heat does not seem to run as much and less drafts. I did add dual pane windows on my current trailer and would not go without them again. We have no moisture on the windows on cold mornings, less drafts, and seems to keep the RV cooler in the summer.
2011 GMC 2500HD Diesel
Old 04-10-2014, 08:28 AM   #4
Oakman's Avatar
Dual pane windows are the one thing I wish I had on our Silverback. When we were in Gulf Shores (high humidity) on chilly mornings we would wake up to windows with so much condensation on them we couldn't see out. Much of that condensation puddled on the bottom of the frame overnight. I used a lot of paper towels on those mornings.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 04-10-2014, 08:49 AM   #5
I do consider R values important. One of the reasons we purchased our 3025 was because of the insulation and thermo pane windows. It makes for more comfortable camping winter or summer since we go camping year round. I also upgraded to the ac/heat pump unit.
mbrolin is offline   Reply With Quote
Old 04-10-2014, 09:18 AM   #6
RSchleder's Avatar
We have been camping for several years and have owned many RV's including 3 diesel pusher class A's plus a Sprinter based class B.
Yesterday we purchased our Wildcat 24RG travel trailer, and YES, R value did play a part in our decision as to which trailer we purchased. We have had broken valves/pipes on our class B while camping in the winter near Dallas,Tx.
Many other factors naturally played a big part in our decision--floor plan, construction, features, cost, amenities.
As to dual pane windows, yes they are nice, however, on our 2005 Allegro Bus "pusher", we has several fog up due to bad seals and they are costly to replace.
RSchleder is offline   Reply With Quote
Old 04-10-2014, 08:20 PM   #7
Our trailer was an RV show purchase, so the specific unit’s R-value had little impact and truthfully would matter little as a practical purchase factor.
An RV has so many thermal bridges and air leaks to make the specific insulation value of a portion of the walls and ceiling to be useless as a measure of overall insulating efficiency. Insulation is presented mostly as an advertising gimmick since you are told you have R-this or R-that in specific pieces of the wall, ceiling, or floor, but not a measure of the as-built unit.
True, you need to have insulation, but unless you redesign and add more weight, you will not be effective as a system. You cool or heat based on total BTUs—the more the better.
Construction techniques, rather than advertised R-values, matter more. The few construction cross-sections I have seen are not particularly impressive from an insulation perspective. Effective advertising of design benefits across all RV systems is lacking.
I would have liked double pane windows from the condensation reduction aspect. A low-E version would be effective in the south.
Our current 12VDC tank heaters were not advertised, but were just a standard feature that a Florida dealer knew nothing about.
The floor radiant barrier was installed uselessly above a supposedly heated enclosed basement but then hidden behind/above a vapor barrier making it useless. Improperly installed, it is useless.
Here is my unit's advertised numbers. Can you spot the errors?
  • Sidewalls: Block foam (R9)
  • Roof: 2 layers of R7 batt (Fiberglass)(R24) and radiant foil insulation (R38)
  • Main Floor: Foam backed radiant foil insulation (R38)
  • Sub Floor: 1/4” honey combed plastic with aluminum radiant foil insulation and forced air heat
  • Front Cap: Fiberglass insulation and radiant foil insulation (R38)
  • End Wall: Block foam (R9)
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
Camped: 2016=6, 2015=9, 2014=27
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
Old 04-12-2014, 08:13 AM   #8
I'm very impressed by this post, pointing to much of the confusing information that has been presented to RV consumers in recent years. There's a growing number of RVs using very high R-values and questionable insulation-enhancing construction and features. Before I go into any further detail, I'd love to hear more about other people's thoughts on R-values and insulation...
Old 04-12-2014, 08:45 AM   #9
Oklahoma Proud
MillerTime's Avatar
Honestly if an rv had a true r9 rating everywhere, that would probably be adequate.
Im sure everybody knows the walls roof and floor are not where the issues of heating and cooling are at for the most part. Its the doors, windows, slide seals, roof vents (1/8" transparent plastic) and sky lights.
I think that if steps are taken to better insulate these, great steps are made towards better efficiency. Just try some bubble foil or vehicle sunshades on a skylight....makes a huge difference (of course makes it darker too).
We have a completely spray foamed house, and it is extremely energy efficient, but we have the air gap, window and door energy losses that are always gonna be more of an issue.
If given the chance on a camper, would I option up on insulation and dual pane windows...yes and I have. But if it only had an r6 it wouldnt make it a deal breaker, as mentioned you have more bigger efficency issues in other places.
Thats just me, I look at the overall realism of a situation.
MillerTime- Future Sabre Handler!!
Old 04-12-2014, 11:26 AM   #10
Firstly I would have to say, there is no truly 4 season RV built by any manufacturer in North America! Not one that can be used north of the 49 th parallel. Not in the sense that it may be used as comfortably in the winter as it would in the other seasons. No hassle water lines and tanks freezing, cold spots or having a furnace run non-stop!
I believe the advertised R values are a bit mis-leading as are the buzz words polar or Arctic package. There are materials available today to make RV's more energy efficient however it's all about cost, and the willingness of the consumer to pay for it.
We have a silverback with dual pane windows and I wouldn't purchase another RV without them. Energy conservation is a big thing these days, and the more energy we save the better. Patiently waiting to get out start camping.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
4 season, all season, arctic, astrofoil, block foam, construction, dense foam, dual pane, enclosed underbelly, four season, insulation, polar, polar package, r-value, radiant, radiant barrier, radiant heat, radiant shield, thermopane, furnace
