Old 05-15-2018, 09:10 AM   #1
dadseven09's Avatar
Insecticide
Just wondering what is preferred insecticide to use in our 5th wheel. At home, we use one that you spray around the inside of the house on the baseboards that works well - Ortho Home Defense. Would this be good for in the camper as well? It is a general insecticide that kills about every insect that moves. Input much aprreciated.
2015 Wildcat 312BHX
2011 Dodge Ram 3500 DRW CC 4WD 6.7 TD
dadseven09 is offline   Reply With Quote
Old 05-15-2018, 09:22 AM   #2
We use the exact same brand in both our house and our RV. Don't see any need for RV use concern. Although we rarely have to use it inside the RV. Just not many insects get inside.
Old 05-15-2018, 09:32 AM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
This is what we have been using for 15 years, we hang the dispenser in the bathroom where we usually find the most insects under the shower skylight.
However, on the packaging it says: Not for use in occupied areas.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-15-2018, 09:38 AM   #4
jeff64's Avatar
For the last couple years I have been using the "Off" product that you would normally attach to a garden hose and spray your yard with to discourage mosquitos and using it in that same manner (dilution) to fill a pump sprayer. I spray the site and weeds. Seems like the little blood suckers have been discouraged by it. I also like the mosquito coils if they get to aggressive. If that's the kind of bugs you're referring to.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-15-2018, 09:51 AM   #5
ben31's Avatar
Whenever I park the 5er at a campsite, I sprinkle this around anything that touches the ground https://smile.amazon.com/Garden-5-Pe.../dp/B004HVWB14
For inside, I spray this once a season to keep any bugs from getting comfortable https://smile.amazon.com/averPak-Sin.../dp/B00CZC27UW
We made the mistake of not using the powder one trip and the ants tried to take over. WE got rid of them and have NEVER forgotten the powder again.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 05-15-2018, 09:51 AM   #6
jd50i's Avatar
Yep, I use home defense also in and around my travel trailer.
jd50i is online now   Reply With Quote
Old 05-16-2018, 09:13 PM   #7
cavie's Avatar
Why would you treat your RV any different than your house? The only difference one has wheels
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-17-2018, 08:44 AM   #8
ben31's Avatar
The reason I use the powder and not the spray, is you can see when the powder needs to be renewed. With a spray, you don't know it needs to be sprayed again, until the critters show up.
Ben and Doreen
Old 05-17-2018, 10:06 AM   #9
SailorSam20500's Avatar
Permethrin is good stuff, from whatever supplier. I think it is better than Deet as a mosquito repellent. However, NEVER spray this on your skin. Also, I have seen reports that some versions remain highly flammable after drying - so don't smoke when wearing clothing with this stuff sprayed on it. (Not that you should be smoking anyway...)
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
