Old 01-05-2018, 07:04 AM   #1
Installing Fireplace
I would like to install a fireplace in my 2015 Wildcat 344QB / I have the small cabinet below TV where I believe I can do this. Has anyone done that?? I have measurements so later will go double check the space.
Thank you
BCopping is offline   Reply With Quote
Old 01-05-2018, 09:57 AM   #2
onetonford's Avatar
Here are some pic's some one on another forum did. I wanted to do the same but he wouldn't reply to my messages.
ID:	159610   Click image for larger version
ID:	159611   Click image for larger version
ID:	159612   Click image for larger version
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 01-05-2018, 10:35 AM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I would try to find a fireplace that fits the opening to avoid modifying the woodwork, be aware of clearance requirements. However, if you are a woodworker the sky is the limit.
Do not plug the fireplace in one of the existing outlets for the entertainment center, install a dedicated breaker (probably 20 Amp) and appropriate sized wiring, the last thing you want is an electric fire from overloading the circuit.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 01-05-2018, 02:55 PM   #4
thanks, I measured and have room but did not know about the wiring. decided not to install at this time
Old 01-05-2018, 03:35 PM   #5
ben31's Avatar
Adding a circuit breaker and wiring isn't real hard. However, if you've never done it, you may want to get a professional or, at least, someone who has some experience do it with you. It isn't hard, but it can be devastating if done incorrectly.
I would add a dedicated 20 amp breaker to the converter/distribution box and 12 gauge wire (at the very least 14 gauge). You can run it under the RV, or along any other existing cable runs.
Good Luck, when you decide to do it.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 01-05-2018, 03:37 PM   #6
ben31's Avatar
Pretty easy with the converter/distribution box right next to it!
Ben and Doreen
Old 01-05-2018, 03:52 PM   #7
Even if you need some help with the wiring, itís a good upgrade. We love ours. We usually donít use the furnace or another space heater.
Of course we havenít been camping in real cold weather.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 01-06-2018, 08:18 AM   #8
cavie's Avatar
Sadly, most circuit boxes are maxed out when they leave the factory. Adding a sub panel is necessary in most cases.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-06-2018, 09:17 AM   #9
llr
Or add it to the AC breaker and don't use the fireplace on heat and the AC at the same time.
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 01-06-2018, 09:25 AM   #10
cavie's Avatar
As an electrician I'm not allowed to say that!
Old 01-06-2018, 10:00 AM   #11
llr
I understand and prefer a separate breaker. I believe RV codes are not as strict as residential just based on what I see. Also if it was 2 outlets and they weren't hard wired then it wouldn't be a issue.
Safety wise I don't see an issue as long as the connections are good
Old 01-06-2018, 10:09 AM   #12
cavie's Avatar
I agree.
Old 01-07-2018, 01:10 PM   #13
Learjet's Avatar
https://www.homedepot.com/p/Square-D...FU7HwAodrnUDYw
see above link...easy to add a double breaker
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 01-08-2018, 07:40 AM   #14
cpaulsen's Avatar
I added one to our 09 Wildcat when we had it and used n external 15 amp plug from the outside.
cpaulsen is offline   Reply With Quote
