Old 10-16-2017, 07:25 AM   #1
Is there an exterior auxiliary propane outlet on our 2018 Wildcat 29rlx. Can't find a
Need help with 29rlx.
pdsulliv is offline   Reply With Quote
Old 10-16-2017, 08:30 AM   #2
Was it ordered with a Outside Grill? Youroo!!
Old 10-16-2017, 09:40 AM   #3
No it was not.
Old 10-16-2017, 12:50 PM   #4
There most likely is not one... But if it is like my 2018 Wildcat 32wb the hose from the stove in the slide is hooked into a quick disconnect that could easily have a tee added to it.
Redrider is offline   Reply With Quote
Old 10-16-2017, 02:34 PM   #5
bikendan's Avatar
Yep, generally you don't get the outside pigtail propane line, if you don't order the grill option.
Many dealers order their units with it, like the our two TTs that we bought off the lot.
But if you ordered it, you have to add the grill option.
Equalizer WDH
Old 10-22-2017, 10:40 PM   #6
SeventyGTX's Avatar
Hmm, our '16 262RGX has one underneath the water heater and we have no outside grill. I discovered it while under the rig mouse-proofing it with spray foam. Just follow your propane lines and you should find out if you have one or not. You have to get under it to spot it.
2016 Wildcat Maxx 262RGX
2016 Ram 2500 Laramie Longhorn 4x4 Cummins 6.7 CCSB Factory Auto-leveling and 5th Wheel Prep w/B&W ball kit, Andersen Ultimate
https://www.forestriverforums.com/attachments/signaturepics/sigpic98816_1.gif
SeventyGTX is offline   Reply With Quote
Old 10-31-2017, 06:52 PM   #7
Mine is underneath just to the left of the steps. I have no outside grill. I did not know I had, just found it one day. It has a quick disconnect.
kdowdy is offline   Reply With Quote
Old 11-03-2017, 11:04 PM   #8
onetonford's Avatar
My 2011 RL has one and I don't have the grill also. It is just behind the slide out on the door side by the rear bumper and it has the quick diconnect.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
cat, exterior, propane, wildcat
