Originally Posted by steveandbarbara
There is a separate button located at the motor that will also operate the landing gears. The retract will not work from there either. Does this sound like the remote (outside) switch? Thanks again
Same as the other answer, I don't know your exact rig, but from what you said, since it is going down, it is not the gearing or it wouldn't move in either direction.
Since the switch is about 10 bucks at any auto parts store, I would do that first. Will probably fix your problem.
If it doesn't fix the problem, then it is a motor issue IMHO and will need to replace it.
