Old 06-22-2016, 08:23 AM   #11
5er_tom's Avatar
Good idea on the contact cleaner. In my case the switch no longer "clicks" when I push it. I am going to Grainger today to get a replacement. It is a 45 minute drive from here. After I replace it, I will see if I can determine what broke inside the bad switch.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 06-22-2016, 04:13 PM   #12
I had this problem and a new switch was not the answer. What I found out was the hydraulic motor pump was requiring more amps than the reset breaker could handle. The reset breaker for my unit came with a 50 amp resettable breaker. I put in a 100 amp resettable breaker and the front jacks work perfectly. Lippert is very difficult to get info out of.
gdwash is offline   Reply With Quote
Old 06-22-2016, 06:34 PM   #13
landing gear switch
Just reverse wires on motor until you get new switch. Save a lot of cranking. Switch wire back when going opposite direction
lawaco12 is offline   Reply With Quote
Old 06-22-2016, 07:56 PM   #14
5er_tom's Avatar
Reverse wires??? Now that is a crazy idea.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 06-22-2016, 08:00 PM   #15
Left Coast
That's all the switch does
Sent from my XT1585 using Tapatalk
Old 06-22-2016, 08:23 PM   #16
Left Coast
PYA move...
Old 06-22-2016, 08:24 PM   #17
Left Coast
Originally Posted by bob caldwell View Post
PYA move...
Wrong thread...
Old 06-23-2016, 04:10 PM   #18
5er_tom's Avatar
The replacement switch from Granger is close, but not an exact match. I did find an exact match at an RV dealer near Denver. It is:
JR Products, part number 13865.
$16.49.
www.jrprvinc.com
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 06-23-2016, 04:20 PM   #19
Left Coast
Put it in one of JR's comparments
Old 06-23-2016, 04:37 PM   #20
cavie's Avatar
Speaking as a 45 year master electrician, remove that 100 amp breaker. You are gonna start a fire and possibly burn down your rig. The wire will burn long before the breaker will trip. Please remove the breaker and get you motor fixed!
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Newley Retired.
cavie is online now   Reply With Quote
