Old 06-20-2016, 09:12 AM   #1
5er_tom's Avatar
Landing Gear Switch Failure
Sure glad my Wildcat came with a manual crank for the front landing gear. The landing gear switch will extend the gear, but will not retract them. I will need to spend some time and find a new switch. We are currently in Gunnison, CO, heading to Cheyenne, WY, on Tuesday. Perhaps there is a good RV shop there.
The access hole for the manual crank is behind the driver side propane tank, but the crank fits through the handles on top of the tank so I need not remove the tank, which is a good thing as the tank is heavy.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 06-20-2016, 09:40 AM   #2
I had the same issue a month ago. The factory replacement is expensive. I went to grainger and ordered a DPDT switch. Its black but oh well. The only thing you have to do is jump 2 terminals. Just pay attention to the back of your current one and duplicate the same way. The numbers are the same on each one, you will see which ones on your current switch to jump. New one works much smoother then the old one too. I bought 2, on for a backup. Make sure you have some fuses for the landing gear as well.
Here is link to switch.
https://www.grainger.com/product/CAR...aa&origin=prod
2015 Forest River Wildcat 312BHX
Reese Goosebox With 5th Airborne Air Ride
TV 2013 Ford F250 Crew Cab 6' Short Bed 6.7 Diesel
Air Bags, B&W Gooseneck
Days Camp 2015 (Since 6/23) 5
"Onward Thru The Fog"
SMN8 is offline   Reply With Quote
Old 06-20-2016, 02:55 PM   #3
Head Rambler
The above link is the correct switch. As said, you need a DPDT momentary-center off switch. The return to center is important because you don't want it to stay on when you press the button.
Gotta go campin!
Old 06-20-2016, 05:05 PM   #4
5er_tom's Avatar
Thanks to both of you. Apparently no Granger in Cheyenne, but the store in Ft. Collins have them. I'll stop by there tomorrow on my way to Cheyenne.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 06-20-2016, 08:36 PM   #5
Left Coast
The weather gets to them.....I put front and rear stabs in compartments with doors.....been just fine since
Old 06-21-2016, 03:00 PM   #6
Don't know about you, but my switch gave out on my FR fifth wheel. So, I used the remote to extend the gear. Not sure if you have a remote.
But my switch is still not fixed. Will be when I get a round tuit.
MOODMAN is offline   Reply With Quote
Old 06-21-2016, 06:42 PM   #7
5er_tom's Avatar
No remote. Hand cranked it down this morning to hook up. Arrived in Cheyenne this afternoon and front of 5th wheel too high. Guess what? The other side of the switch broke. Now I have to hand crank both up and down.
I called FR dealer here in Cheyenne about a new switch and was told it would take at least 5 weeks to get
One as FR is very busy. I called my dealer in NC, Bill Plemmons, and it was ordered today with 3-5 days to ship. They will ship to a place we are going in CA.
I know the FR switch is waymore expensive than the one from Grainger, but the FR switch comes with the wiring harness already connected. I looked and it will be an easy swap out.
I will get one of the Grainger switches for a backup.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
Old 06-21-2016, 07:04 PM   #8
Left Coast
Six terminal slide switch works also...
Sent from my XT1585 using Tapatalk
Old 06-21-2016, 07:05 PM   #9
Left Coast
Switches also available on Amazon
Old 06-22-2016, 06:56 AM   #10
Landing Gear Switch
A few years ago when I left a campground my landing gear worked fine. 250 miles later when I arrived home the gear would not extend. Everything checked out fine other than the switch. Before I ordered a new switch I decided to go to Walmart an bought a can of contact cleaner. Disconnected all electrical power to switch. Sprayed the contact cleaner in switch and worked switch for about 5 min while reappling cleaner. reconnected and never had a problem again. Now every few months I apply cleaner to all outside switches as a precaution.
Joe and Teresa
Retired from Georgia State Patrol and very proud of it.
2010 F250 King Ranch Crew Cab 6.4L Turbo Diesel
2011 Cedar Creek Silverback 29RE
gsp050 is offline   Reply With Quote
