Old 10-10-2016, 08:20 AM   #1
leaking Slide - top edge
my 2006 5th wheel slide is slightly leaking. It is in the top corner where the roof meets the outside wall. it is moist.... thinking it is where the roof meets the outer wall. Can I just use the lap sealant like on my roof? or is there other sealant that I need to put on that edge?
Blackbelt is offline   Reply With Quote
Old 10-10-2016, 05:03 PM   #2
cavie's Avatar
If your roof sealant is self-leveling you can not use it on a vertical surface. Is the damage on the trailer or the slide?
2002 27rk Wildcat
Port Charlotte Fl/Hinsdale Ma
Newley Retired.
Old 10-11-2016, 12:29 PM   #3
Head Rambler
I would use eternabond tape to repair it. You don't want lap sealant on there where the lip or seal could drag on it.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
leak, slide
