Old 09-12-2015, 08:30 PM   #11
Did they ever fix your leak in bedroom slide?
Dan Perkins is offline   Reply With Quote
Old 09-12-2015, 08:32 PM   #12
Did they ever fix the leak in your bedroom slide? What year is your 295rsx?
Old 09-12-2015, 08:47 PM   #13
Mr. Dan's Avatar
Dan, if you're asking me, the answer is No... but my 2015 295RSX (picked up in July of 2014) is going to a local dealership Tuesday to have 3 slide toppers installed at no cost to me.
To all... please don't poke the F. R. hornet nest until I get my unit home after this installation! Thanks.
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 09-12-2015, 11:53 PM   #14
Blog: RVroadtripper.com
hbillsmith's Avatar
I had my 2016 295rsx built with slide toppers from the factory. Been thru at least two very hard rains and no leaks. I paid $700 for the set of three and looks like it was a wise add-on. Pure luck for me, I was just thinking it would cut summer heat (it did).
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 09-13-2015, 04:58 AM   #15
Witch Doctor's Avatar
Originally Posted by Mr. Dan View Post
The bedroom slide in my 295RSX leaks. It's been "fixed" by the dealership 3x and still leaks. It was "fixed correctly" at the Goshen rally and it leaked on the way home.
[I didn't know they had stopped making the 295RSX!]
Where is your slide leaking at? Can you pin point the area with a picture? I'm sure one of our smart FFM would be able to help dealers are useless. I was told by my x-dealer that FR only requires them to send 1 teck to class to make the dealer certified.
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-13-2015, 09:04 PM   #16
Mr. Dan's Avatar
Leaky Slide out Brand new Wildcat 275ckx
I normally post pics off my phone using Tapatalk, but uploads have failed all day. The left (looking from inside) end of the bedroom wardrobe slide leaks onto the vinyl flooring on the bathroom floor. Fortunately, it does not leak on carpet. I can put a cup in a certain place near the shower and catch every drip but I don't really want water on the inside of the slide walls.
I wouldn't have guessed my dealership had ANY certification process. I think some techs at my shop were laying brick last week and some were working in a nursing facility.
Sent (I think)
Old 09-15-2015, 05:57 PM   #17
Torch's Avatar
I'm still waiting for the seal kit that FR left off the bedroom slide.
Torch is offline   Reply With Quote
Old 10-28-2015, 03:21 PM   #18
Mr. Dan's Avatar
My last pic post attempt just worked so I'll try a pic answer to your question.
Sent (I think)
Old 10-31-2015, 10:01 AM   #19
Mr. Dan
Looking at your picture, this is exactly where ours leaked last night. I have already use two thick extra large bath towels, and the water seems to keep seeping in. It's not even raining anymore, but the leak continues. Have you found a solution yet ?
TxBgWood is offline   Reply With Quote
Old 10-31-2015, 10:10 AM   #20
Who Dares, Wins
doc73's Avatar
Is there a drain tube and or catch cup under there at all.. I do not have your TT but our slide has a drain tube that lays in a small catch tray (like a little tub if you will, 3x6 or so ). Water drains into this then out the trailer bellow, could the tube be out of place?
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
cat, leak, slide, slide out, wildcat
