Old 08-31-2019, 08:31 PM   #1
LED Front lights
Where does one get these lights from? I have one not working.
Mike
Juniorz is offline   Reply With Quote
Old 08-31-2019, 08:36 PM   #2
robbiels7's Avatar
Most likely you may have to do some digging. Pull it off , it will have a part number stamped on it. Google it or even ebay or Amazon. If not dont limit your self you can easily adapt anything similar 12 volt.
Mike
robbiels7 is offline   Reply With Quote
Old 09-01-2019, 10:42 AM   #3
5er_tom's Avatar
I would be curious to know if you find them. Mine appear to be the same as your and don’t work either.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2018 Ford F-350, 4x4, Diesel, CC, Long Bed
5er_tom is offline   Reply With Quote
Old 09-01-2019, 11:19 AM   #4
robbiels7's Avatar
Just a fast search on Amazon i found these and there are alot to choose from. Different lengths and colors. Click image for larger version
Old 09-01-2019, 11:52 AM   #5
Looks like its got a strip glued into the housing, no part number and the wiring is tight. this is what it looks like behind the housing.
Will look later for something.
Old 09-07-2019, 06:21 PM   #6
Learjet's Avatar
I had to replace both of mine...here was the only place I could find the same ones.
https://thmarinesupplies.com/product...=4718845132838
they are a little pricey...the new ones seem to be slightly updated.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 09-07-2019, 08:47 PM   #7
My Flagstaff has lights that look really close to those and I think I paid about $40 to get them from Forest River.
bigmurph is offline   Reply With Quote
led, light
