Old 02-14-2014, 06:21 AM   #101
The ones I used are the ones below. The first link is the bulb that goes into the little halogen lights that look like small frosted glass discs. Those things get incredibly hot with the halogen bulbs. The second link is the bulb that replaces the standard 921 incandescent bulbs which is probably what you have in most of your fixtures. Hope this helps!
10pcs G4 9-5050 SMD LED Bulb Lamp,Warm White NEW #WZ (181054129452) | eBay
10x T10 194 921 W5W Bulb Lamp 12 5050SMD LED Warm White Y | eBay
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 08-21-2014, 08:46 AM   #102
JAYCO Representative
Wildcat Chris's Avatar
We will be adding even more LED lighting to the next revision of Wildcat -- more to come on that!
Wildcat Chris is offline   Reply With Quote
Old 10-05-2014, 09:39 PM   #103
Phat Phrog Stunt Crew
elind's Avatar
My Wildcat has LED lights and when I turn on the lights with the radio on, the radio reception dies. Is it common that LEDs interfere with the radio?
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 10-05-2014, 10:00 PM   #104
That all depends on the LED. Some are notorious for EMI while others do not. Most folks experience the most interference when a dimmer is used.
rana is offline   Reply With Quote
Old 10-05-2014, 10:20 PM   #105
2012 Solera
Not the LEDs but the drive circuit. DC drive through a resistor -no rfi. Pulse drive (usually IC instead of resistor) can cause rfi. Driver can be built into LED unit. A dimmer is an external driver - usually IC pulse drive.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-05-2014, 10:23 PM   #106
BooBoo23's Avatar
Originally Posted by PhotoMaster View Post
Does anyone know if these are the same bulbs as in the FR3? I would order them right now if I knew for sure.
You need to remove the bulb to tell what type of base it has. For a wedge base it will be a T10. Most halogen bulbs are 2 pins which is a G4 base. There may be other types of bulbs used in your RV so look at each one individually. There will be at least 2 different types of bulb bases used for interior lamps. Exterior marker lights will be most likely T10 base just make sure the bulb assembly is not longer than 24mm or it will not fit under the lens cover. Brake turn lamp assemblies will most likely be a BAY- 15D base. Search around on Ebay to determine what style of base matches your bulb. Also most led bulbs have polarity so turning them 180 degrees may be necessary. Those with no polarity will be identified as "Error Free".
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
BooBoo23 is offline   Reply With Quote
extralite, led, sterling, wildcat, light
