Old 04-27-2013, 01:10 PM   #81
psaman's Avatar
Originally Posted by BarryD0706 View Post
Inside makes sense if you boondock. Outside: Why?
FWIW, I discovered that LED's in the porch light do not attract flying critters. In our old trailer, every time we opened the door, being right next to the light, bugs would fly in.
2019 Rockwood Ultralight 2898KS
2018 Dodge Ram 2500 HD 6.7 Cummins
psaman is offline   Reply With Quote
Old 04-27-2013, 02:00 PM   #82
Taylorgso's Avatar
Replaced my inside bulbs. I don't see any need to replace the outside bulbs (running lights, etc) other than maybe the entry door light (porch light), and i'll probably replace that soon. I consider the expense to be a one-time investment since LED bulbs have such a long service life. With my old RV I had to replace several fixtures and I suspect they went out due to exposure to heat from the bulbs - not a problem with LED's.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 04-27-2013, 02:43 PM   #83
crunchman12001's Avatar
Originally Posted by Portagie1968 View Post
What we have found out so far is if you replace just the bulb they are not as bright as if you buy the whole fixture. So we just chose what light level we need and place accordingly. Example. Closet and under stairs does not need to be as bright so we replaced blub. Bathroom needed more light so we replaced fixture.
Portagie1968,
Thanks for the heads up on the "buying the bulb vs buying the fixture".
I had wondered why the fixtures were so expensive compared to just the bulbs.
crunchman
2015 F-250 FX4
Old 04-27-2013, 03:55 PM   #84
Filterman's Avatar
LED lighting
Outside for life.. If you do a lot of off road trailering in a concentrated time ( we do)! They stand up forever to vibration.
Filterman is offline   Reply With Quote
Old 04-27-2013, 04:11 PM   #85
Garrette's Avatar
I am slowly replacing the fixtures. Reason, heat, long life, low power draw and the fixtures have the ,one side on, both on. They are brighter. I have replaced 6 so far. Will get to the rest as they go on sale somewhere.
I just consider it an upgrade, and yes, I will replace the door fixture. Leave it on and no worries about heat.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 08-15-2013, 06:23 PM   #86
JAYCO Representative
Wildcat Chris's Avatar
LED lighting seems to finally be almost everywhere in the RV manufacturing world now! The pricing has really come in line to use it very widely and now we've even started to see some really great uses in decorative or fun applications (more to come on this!).
How important is LED lighting in your buying decision for any RV?
Wildcat Chris is offline   Reply With Quote
Old 08-18-2013, 03:23 PM   #87
Filterman's Avatar
Has anyone found a good colour and lumin level to replace the inside existing bulbs, and still give good visibility fir reading etc. also source?Thank you
Old 08-20-2013, 06:05 AM   #88
So far have only changed two bulbs in our unit. The 'spot light' reading lights over the bed were getting so hot so I found two multi-LED's on line. What a difference and much better light. I'll be looking at swapping more as time passes.
JJnLilly is offline   Reply With Quote
Old 08-20-2013, 05:28 PM   #89
duradiesel's Avatar
I switched all my lights to LED'S .We don't have power sites all the time so we save a lot power. I have the bright white & like them. I also installed them in the outside lights. I think all RV'S should have them from the factory.
duradiesel is offline   Reply With Quote
Old 08-20-2013, 05:35 PM   #90
hkreck's Avatar
I just replaced all the light inside my Solera started out with bright white but then switched over to the warm white light over the dinning area and bedroom. still have the bright white over the main room.
Henry & Tena
hkreck is offline   Reply With Quote
Old 08-21-2013, 09:12 PM   #91
I'll see if I can get some answers on this from our LED supplier. Here's their web site if you're interested:
12 volt lighting designed and manufactured by Command Electronics
Old 02-12-2014, 10:12 AM   #92
I was asked about some of our decorative lighting (which is also now all LED) -- it's supplied by Gustafson Lighting:
R.B. Gustafson Corp.*::*Lighting 12-volt
Old 02-12-2014, 10:51 AM   #93
PhotoMaster's Avatar
I see fluorescent, incandescent and halogen, but no led.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
Old 02-12-2014, 11:57 AM   #94
Hmmm... you're right. Maybe they haven't updated their site/catalog. Let me see if I can find a more recent link or info. They are a subsidiary of Patrick Industries: Patrick Industries
Old 02-12-2014, 12:02 PM   #95
Our standard LED lighting is from Command Electronics. Lots of great info here:
Old 02-13-2014, 05:47 PM   #96
We originally had a 23SS travel trailer and it had led lighting throughout. We traded it in and got a 2014 FR3 30DS which has incandescents throughout. I want to find the best way to upgrade, with hopefully just replacing bulbs. I'm afraid it won't be that simple. Our rig is in service right now, so I can't even figure what bulbs I would need.
2014 FR3 30DS
Old 02-14-2014, 05:59 AM   #97
_nelsonc's Avatar
I replaced all my incandescent lights in my 2013 Coachmen Mirada 35DL with these: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1. Quality is excellent as is the brightness.
_nelsonc is offline   Reply With Quote
Old 02-14-2014, 06:28 AM   #98
I replaced all of mine about a year ago and bought them direct from China. I hated to give them my business, but I could not afford to buy them in the US for this price. Besides, I'm sure that whatever you buy will come from China and will be marked up a bunch. I have not had a single failure. The super bright are too harsh a light and really not as light as the bright warm lights.
2011_led | eBay
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 02-14-2014, 06:44 AM   #99
Does anyone know if these are the same bulbs as in the FR3? I would order them right now if I knew for sure.
2014 FR3 30DS
Old 02-14-2014, 06:47 AM   #100
2011_led | eBay
These are some awesome bulbs! I just don't know which ones I'd need for the FR3.
2014 FR3 30DS
extralite, led, sterling, wildcat, light
