Old 07-29-2015, 04:25 PM   #1
Lights not working
We have recently had our 2015 Wildcat in for service and went to pick it up to find that none of the lights are working or anything electrical in the camper except the jacks and slide outs. It is currently hooked up to only the battery in the RV storage facility.
Any suggestions?
roadk01 is offline   Reply With Quote
Old 07-29-2015, 04:46 PM   #2
Georgia Frog Rally 2018
aceinspp's Avatar
Little confused by the post. Did the lights work when you piked up from dealer? If the trailer and not the TV are not hooked together and trailer plugged into power at the facility, the running lights will not work. Being plugged in at the storage facility lights should not work on trailer. Now if your TV are both at the storage facility and hooked up with plug in to trailer then you may have blown a fues in the TV. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-29-2015, 04:50 PM   #3
When we picked it up we moved it to the RV's storage facility to pack for an upcoming trip. If the RV is connected to it's battery, which it is, I should be able to operate interior lights and other electrical items off the batter of the RV. Nothing electrical in the RV works except the leveling jacks and the slide outs, no interior lights nothing.
Old 07-29-2015, 04:54 PM   #4
Flybob's Avatar
Check fuses and battery cut off switch if you have one. Depending on how it is wired, bat cutoff could cause that. Not sure what work was done, but dealer may have blown fuse between battery and converter ( usually 30A-40 A orange or dark yellow)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-29-2015, 04:55 PM   #5
aceinspp's Avatar
Have you checked to see if you have a battery disconnect switch on the camper. Check your fuse panel in the camper may have a fuse blown. Later RJD
Days camped 2017 62
Days camped 2018 18
Old 07-29-2015, 04:55 PM   #6
Thanks Fly Bob, checked it and the fuses but still no workie
Old 07-29-2015, 05:00 PM   #7
Flybob's Avatar
They may have disconnected battery from converter ( and lighting etc.) the two big items that work may be connected to battery directly thru their own fuses. Make sure convertor power cables are connected to battery.
TST Tire Monitors
2 100W solar panels
Old 07-29-2015, 05:02 PM   #8
Thanks Fly Bob,
From a cursory look at the battery earlier I didn't see anything not connected but I'll go back and take a closer look.
Old 07-29-2015, 05:07 PM   #9
Is there a switch on the converter somewhere that could be turned off?
Old 07-29-2015, 05:17 PM   #10
Flybob's Avatar
Did you check the two large fuses.
TST Tire Monitors
2 100W solar panels
light
