Old 09-04-2015, 12:17 AM   #1
lippet remote doesnt work
Hey Guys
Just bought a new wildcat, im having trouble programing the Lippert remote, I tried the steps on the manual and nothing works except for the outside light, any help would be much appreciated
joeallphase is offline   Reply With Quote
Old 09-04-2015, 08:53 AM   #2
The good news is that the outside light works. That says that it's communicating with the receiver.
Do you know where the receiver is located?
What model is your Wildcat?
What equipment do you have that the remote should be operating?
Do all the manual switches operate the items correctly?
Do you know how many functions the receiver can perform. (Common ones are 5 and 8.)
Gotta go campin!
Old 09-04-2015, 05:35 PM   #3
I know where the receiver is
Model IST30DBH
awning
Slider
Front and rear stabilizer
Main light
Manuel switches work fine
8 function
Old 09-05-2015, 03:30 PM   #4
When you press the remote buttons, do you hear any of the relays click?
Was the receiver factory installed?
Are the functions programmed, but just not operating when you press the buttons?
Gotta go campin!
Old 09-05-2015, 03:34 PM   #5
your relay is under front door rite side behide the black thin sheet
scott kohlenberg is offline   Reply With Quote
Old 09-06-2015, 06:54 AM   #6
wwalker2984's Avatar
There is fuses in the remote board were the relay are and one they feeds 12v to the board
wwalker2984 is offline   Reply With Quote
Old 09-10-2015, 07:30 PM   #7
[QUOTE=Bama Rambler;975347]When you press the remote buttons, do you hear any of the relays click? No clicking only for light switch
Was the receiver factory installed? Yes
Are the functions programmed, but just not operating when you press the buttons?correct
Old 09-10-2015, 07:59 PM   #8
Have you checked all the fuses on the receiver?
Do you hear any clicks at the receiver when you press the remote buttons?
Verify for me that the outside light works with the remote.
Gotta go campin!
Old 09-11-2015, 03:19 AM   #9
did u change battery inromote ? i had to on mine
Old 09-11-2015, 08:21 PM   #10
All the fuses are good getting power checked them with multi meter. The receiver clicks only for the light though and it does turn on outside
What is the configure fuses for?
Old 09-11-2015, 08:24 PM   #11
If you press yes on fuse configure it asks for a pin. Someone told me only a authorized dealer can get that pin in order to reconfigure. Could that be why it's not working
Old 09-12-2015, 12:02 AM   #12
Having the exact same issue on my 30DBH. Would love to find a solution.
MrRaven is offline   Reply With Quote
Old 09-12-2015, 12:04 AM   #13
Glad you responded, do you have the wildcat 30dbh?
Old 09-12-2015, 12:07 AM   #14
I'm towing with my ecoboost and after reading all the posts in this forum I'm wondering if it is to much for my truck, what is you towing vehicle
Old 09-12-2015, 12:08 AM   #15
On the remote issue if I get it to work I will let you know
Old 09-12-2015, 07:42 PM   #16
The fuses get configured for the outputs, you shouldn't need to reconfigure them.
It's strange that only the light works.
Did it ever work?
Have you changed the remote since you've owned it?
Have you tried reprogramming the outputs? Except for the light.
It could be that the receiver is bad, but I'd do more research before replacing it.
Just in case, they have several on Ebay that are identical.
Gotta go campin!
Old 09-13-2015, 09:56 AM   #17
Well mine stopped working and had to get other one relays were working but no out put on the board I called FR in Oregon told them I had no out put and after telling them I felt the dealer was incompetent to do this work they sent one out to me so on that note ck your out put voltage if there is none you Need a new board
Old 10-07-2015, 06:47 AM   #18
RSchleder's Avatar
When I picked up my Wildcat, 1 of the functions on the remote did not work. The technician changed that function on the receiver to a different (spare) channel, reprogramed the remote to that channel, and everything continues to work just fine a year later. So, it is very possible you have a defective receiver with several bad/inoperative channels.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
