Old 09-15-2014, 02:11 PM   #1
Location of water pump 312QBX/312BHX
Anyone know the location of the water pump and how to access it on a 2015 312QBX? Should be the same as a 312BHX. I want to check the backflow valve and install a silencer kit.
Thanks, Jeff
SNOMORE is offline   Reply With Quote
Old 09-15-2014, 11:58 PM   #2
Thanks, Jeff
In the main pass thru storage, behind the connection center where the water connections are... If you remove the panel on the back of the storage area (facing the rear of the trailer) you can then get to the screws that hold the coroplast in place that hides the pump and water connections...
--Paul
pbryan is offline   Reply With Quote
Old 09-16-2014, 10:55 AM   #3
Perfect - that's what I suspected but I wanted to be sure before tearing anything up. Thank you!
312bhx, cat, location, pump, water, water pump
