Old 05-07-2015, 10:45 AM   #1
Looking for these products
I am looking for some items I am not sure are made anymore. They are as follows:
(1) "Wally washers". The best hose washer made. I understand they were made by Marshall Brass, and that company is no longer around or bought by someone, and this item disappeared. These are a soft rubber, that does not get hard. They are also tapered from the thicker center to outside edge. They will fix leaky hose ends and make the city water hook-up leak free, also. I have a couple of them left, and they are 15 years old and very pliable.
(2) I use to have a rubber cover for the pin on my 5th wheel. It was a round cover that just covered the pin itself. It kept the grease contained, and acted as a cushion for the top of my head, when I would forget to duck. It was a very practical and inexpensive item that pushed over the pin.
(3) I had a set of wheel chocks that were made of cast aluminum. I really like them. I cannot read the manufacturers' name on them. I lost one, and need a replacement (new or used) I will attempt to add a photo to this post.
These are Items that I have used with my 5th wheel trailers for 25 years. I hope someone out there has some knowledge of these items and where I may locate any of them. I have looked at other items on the market, and found nothing that comes close to replacing the quality or are as easy to use as these items.
Dug2013 is offline   Reply With Quote
Old 05-15-2015, 12:13 PM   #2
muddyrode's Avatar
for the pin cover you may be able to use a trailer hitch ball cover upside down
if it is little to big take a heat gun and shrink it a little
i have a pullrite hitch and don,t greese mine other that a little spray oil
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is online now   Reply With Quote
Old 05-15-2015, 12:21 PM   #3
B47
I Goggled Wally Washers and had 9 hits,but they are all latex gloves.
You could also slit a tennis ball and slip that over your king pin.
Old 05-15-2015, 12:25 PM   #4
This site has a big cushion for your fifth-wheel. Safe Zone Corp
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
