Old 09-13-2017, 10:13 AM   #1
Manually extending slide outs?
I have a 2017 Wildcat with cable driven slide outs. The motor for the slides are centered over each slide which is 10-12 foot long. I received a small 12" flex tool for my drill that is intended to be used to work the slides manually if necessary. There is no possible way to reach the slide motor. Is there some other point that the tool is used on? What am I missing?
rshirah is offline   Reply With Quote
Old 09-14-2017, 09:03 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I'm sure someone with a wildcat will chime in and answer your question.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-22-2017, 12:11 AM   #3
Witch Doctor's Avatar
You have to use that on the motor end with a drill, sometimes you have to remove the trim in front to access it. Your slide is called a accu.slide
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-22-2017, 12:12 AM   #4
You can see how to do it in a video by lippert on the internet
Coachmen M/H
Concord
2018 / 300 DSC
manual, slide, slide out
