Old 12-20-2013, 07:46 PM   #1
Question More questions, sorry lol
I have couple of questions I hope someone can answer for me.
1: How does the sewer tank flush work? I hooked up my secondary hose and got nothing, and when I cut off the water it still had pressure on the hose which tells me it isn't flowing any water. Any ideas?
2: There's a little white on-off-on switch mounted beside the hydraulic pump up front. Any ideas? Can get a picture if needed.
06 D-Max CC 4X4
2014 Wildcat 344QB-OK
EastTexan is offline   Reply With Quote
Old 12-21-2013, 04:23 AM   #2
Campfire Master
Somewhere in the flush line there is a pressure break/anti-siphon valve. Mine was plugged up pretty good with sawdust. Sounds like yours is totally plugged. On my old Wildcat, it was behind a panel in the bed room. In my current one, it's under the bathroom sink.
That little switch is an emergency by pass switch that will run the hydraulic pump.
John
AVid is offline   Reply With Quote
Old 12-21-2013, 05:14 AM   #3
wfmdfm's Avatar
When we got our trailer new I had the same issue. It turned out that the hose was kinked in the rats nest of wire and hoses behind the sub woofer.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 12-21-2013, 06:37 PM   #4
jevanb's Avatar
the switch is for the hyd pump, just hit it and you will see, as for the flush mine was hooked up to the fresh water fill , yours prob has a stuck valve in the master wall bathroom behind the panel
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 12-21-2013, 09:09 PM   #5
The only valve I found was this one.
Thanks for the info.
06 D-Max CC 4X4
