02-26-2014, 09:21 AM
#41
Ret E-9 Anchor-clanker
I might have what you call a 4-point. I don't have a 6-point but have experienced it during viewing at dealerships/shows. As a full timer (2010) traveling from Chicago - California, I experience bounce (as most do) on my 5r. Old Coot installed scissor jacks under the center line next to the axels to reduce this bounce. His mods are so awesome. My rear electric stabilizer is a great feature. Would adding another electric center stabilizer be that much more? It doesn't need to be a auto self leveling system rather an additional stabilizer.
02-26-2014, 12:59 PM
#42
Originally Posted by kerrlakelover
First Chris...thanks for being "brave enough" to participate in our forum!!! It is great that you interact with us here. THANK YOU.
My tire guy is a fan of Maxxis. He has been in the tire, towing, and auto repair business for 40 years. Being in the towing business he has multiple trailers supporting his business and has had personal experience with many tire brands over the years. He is a fan of 3 trailer tire brands...Maxxis, PowerKing Towmax, and Goodyear Marathon. NOTE: He has no real preference one over the other.
He is very keen on insuring the tires are sized, maintained and loaded properly. Like many have said on this and other forums, many of the tire issues fall squarely on the consumer for not taking care of the tires (proper loading, load balancing, tire pressure, proper speeds, etc). But, he also agrees with us in that many of the brands made off shore which are not strictly regulated by a reputable Brand (ie Goodyear, Power King, Maxiss) are not worth running on an off road farm trailer. He has seen what he says are way too many roadside service calls in which he knew the almost new "x brand" tires were used properly and the tires failed. This guy knows his tires, and if there's anything left of the failed tire, can tell you pretty much what caused the tire to fail.
Finally, I'm a business man and I fully understand how challenging it is to run a profitable business in today's world. I also understand cutting corners anywhere you can to reduce costs. But, the RV industry has an obligation not to cut corners on tires, wheels and suspension. These items should not be skimped on in the name of profit and put people's lives in danger. OK, that's my editorial comment. Thanks again Chris!!
In the RV world, tires are such an issue that good tires would be a major selling point, so much so that you could pass the cost directly on and few would blink.
02-26-2014, 01:02 PM
#43
You may want to put the jt strong arms on it took alot of the bounce of my 5er
02-26-2014, 02:18 PM
#44
I bought a portable ice maker on line from Wally World. best $79.00 invest I made! Just keeps making ice. perfect for those long hot weekends!
02-26-2014, 02:29 PM
#45
The ice makers are worth there weight in gold
02-26-2014, 06:17 PM
#46
Plain Old Member
As for the 3 AC's, I'd say mostly on the bunk house models, or at least the longer units. Get the same length bus, say 35-40 feet, and you'll see 3 of them, and they need them in the south. I've seen plenty of toy haulers being offered with them now, and though it's not an option that I know of, I've seen a Silverback 35QB4 with a third in the bunk house. This summer will be a test, but it's a possibility we'll be adding at least a small penguin unit in the bunk room.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
02-26-2014, 10:22 PM
#47
Originally Posted by Wildcat Chris
Is anyone here a fan of Maxxis tires?
+1 for Maxxis. I have run Maxxis on my boat trailers and previous TT for years.
02-26-2014, 10:24 PM
#48
JAYCO Representative
You've all made it easy for me.
MAXXIS tires will be an available 2015 Wildcat upgrade.
More to come on this...
02-26-2014, 10:57 PM
#49
NELA
Lucky future Wildcat owners!
Heck if summer doesn't show up soon we'll need All Terrain TA's on ours to get it out of the back yard.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
02-26-2014, 11:07 PM
#50
I don't have a Wildcat but have just bought a Cedar Creek. What does surprise me is none of the units appear to come with a built in surge protector. If these units are at risk from questionable electrical supplies sometimes found at even the best RV resorts, surely a $300 - 400 surge protector could be built in at the point of manufacture.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
02-26-2014, 11:57 PM
#51
OEM installed solar power on board as an option/upgrade.
Even if it only comes with a 30 day warranty - Getting mine installed on my 5th aftermarket was kind of a nightmare of Trust but Verify ... Luckily for me the guy knew what he was doing but it was stressssssful for me! I would have absolutely opted for OEM provided had the option been offered.
02-27-2014, 08:21 AM
#52
Camper Less Camping
Option to replace rubber roof with similar MH style fiberglass roof
Great move on adding Maxxis tires to option list for 2015!
2013 Sabre 32RCTS-6 (sold)
02-27-2014, 08:37 AM
#53
Might consider having factory integrated levels. I've never been on a factory tour, but I'm assuming the mfg floor is level. Final assembly would be the perfect place to nicely integrate side to side and front to rear levels. For the novice RVer it would be a big help. It would even be of benefit to us experienced guys and save us the effort of having to figure out how to level our units to install the bubble levels that most of us install.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
02-27-2014, 09:39 AM
#54
Always Learning
Awesome! The Maxxis are what I opted for when I replaced my camper tires. For me, it came down to them or Goodyear Marathons.
02-27-2014, 09:53 AM
#55
Ham Radio since 1970
One thing I have not seen listed is quad steps, if not already installed. We changed from three steps to four, and it really helped my wife's back and knees.
Would also love to see a coat closet, more towel racks in the bathroom and 115V outlets on both sides of the bed.
Mike
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
02-27-2014, 09:03 PM
#56
Understood. We've heard this before. All Wildcats for 2015 will come with quad step entryways... just confirmed it today.
Mike
While the coat/broom closet idea is somewhat floor plan dependent (our 295RSX, 327CK, and 333MK all have it!), every single Wildcat floor plan today features 110V outlets on either side of the master bedroom bed!
03-01-2014, 11:05 AM
#57
We have a 2003 27RL Wildcat, we love the "his and her dual closets" each with four draws underneath at the top of the stairs. I don't see that in the newer wildcats and would like to. The 2003's have storage that is second to none and that's what 's important to the DW! Some of the newer units have a closet slide in the bedroom but that increases the weight and when your towing with a 1/2 ton truck weight is very important, especially pin weight.
2003 Wildcat 27RL
2008 Toyota Tundra 5.7L Crewmax
Superglide 3100 Autoslider Hitch
Timbren SES
Prodigy P3 brake controller
03-01-2014, 11:20 AM
#58
1) Maxxis 2) Marathon 3) 4 point electric leveler system 4) 6 point hyd. leveler system. 5) Progressive convertors with the wizard 6) shut off valves inside for low point drains. 7) shut off a valve for outdoor shower inside. 8) heat pumps with FAU back up/ no straight A/C units. 8) digital stats 9) house grade faucets and fixtures 10) stainless steel sinks.11) motion sensor lights outside 12) all led inside 13) hard wire surge protectors.14) jack antennas...I could do this all day..... (#6 & 7 for winterizing)
Coachmen M/H
Concord
2018 / 300 DSC
03-01-2014, 12:13 PM
#59
I own a Rockwood, these are options I would like:
(use Made in USA products when possible)
-5th Airborne Sidewinder
-Goodyear or Carlisle Tires (I installed Goodyear on day of purchase)
-Progressive Surge Protector (I have an external unit)
-Awning Covers
-Winfield 5th Wheel Landing Gear Cross Brace Stabilizer
-Maxxair Vent Covers (I installed 3)
-Fan inside fridge (I have a battery operated portable unit)
-Ventilation Fan on back of fridge (factory installed 1, I installed 2 more)
-Shock Absorbers
-Blue Ray player
-Winegard RV Antenna with Wingman (I installed the Wingman)
-Rhino or Linex or RV FlexArmor on the roof (I would really like this!)
My unit came with many options I like, I will not list them all, but these are the items that really stand out:
-Power Rear Stabilizer Jacks
-Built in Winterize set up
-Ceiling Fan
-Power Awnings
-Battery Disconnect
-2 Easy access compartments to: water heater, pump, water lines, filter
2014 Rockwood 8289WS - Goodyear Tires
2022 F350 King Ranch Crew Cab
4x4 - 7.3L - 3.73 - 6 1/2 bed - Michilien Tires
Timbren & Anderson Ultimate 5th Wheel Hitch
03-01-2014, 12:40 PM
#60
I did notice Goodyear Marathons were an up grade on a 2014 something that our dealer had on the lot. Forgot to check the option price. I like to just check out the newer models made me so glad we have ours Maybe manufacturers are starting to listen to the buyers at least some want the option of better tires.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
