Old 02-25-2014, 10:03 PM   #31
onetonford's Avatar
Originally Posted by Wildcat Chris View Post
Is anyone here a fan of Maxxis tires?
Yes would like to have a set on mine already blew out one tire in the second season of use. Also wouldn't mind if it had to jacks just behind the axles to keep the trailer from bouncing on the springs.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 02-25-2014, 10:09 PM   #32
Vinster30's Avatar
3 Ac units
Vinster30 is offline   Reply With Quote
Old 02-25-2014, 10:11 PM   #33
Plain Old Member
Most needed upgrade in today's fifth wheels...
I second the 3 AC units.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 02-25-2014, 10:46 PM   #34
OL Creeker's Avatar
Towing in the snow
When I saw that pic, I couldn't believe it. But once I realized you were driving south, I felt much better! We were in some very cold conditions on our way back to AZ., from the factory 11/21 and had the furnace set to 60 while en route. Never again!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 02-25-2014, 10:49 PM   #35
iceblaze580's Avatar
The 6 point offers more stability
iceblaze580 is offline   Reply With Quote
Old 02-25-2014, 10:57 PM   #36
JAYCO Representative
Wildcat Chris's Avatar
Is this specifically for bunk houses? Hard to imagine 3 AC units on a smaller, couple's style floor plan!
Wildcat Chris is offline   Reply With Quote
Old 02-25-2014, 11:00 PM   #37
That's true on a longer unit for sure. What about on a shorter unit -- possibly overkill at 30'-34' total length...
And do you prefer hydraulic over electric? Or does it matter?
Old 02-25-2014, 11:03 PM   #38
Hydraulic is a bit heavier and messier if you blow a line I have the electric on my columbus my dad has hydraulic leveling system on his cardinal
Old 02-25-2014, 11:14 PM   #39
SKnight's Avatar
Might have been mentioned, but the ability to attach SOMETHING to the rear bumper without voiding the warranty on the chassis. Once I lost the use of my bed, now I need to figure something out about transporting my motorcycle. I went with the Sierra because I fell in love with it, but that is still a major issue I'll need to figure out.
Old 02-26-2014, 08:11 AM   #40
kerrlakelover's Avatar
First Chris...thanks for being "brave enough" to participate in our forum!!! It is great that you interact with us here. THANK YOU.
My tire guy is a fan of Maxxis. He has been in the tire, towing, and auto repair business for 40 years. Being in the towing business he has multiple trailers supporting his business and has had personal experience with many tire brands over the years. He is a fan of 3 trailer tire brands...Maxxis, PowerKing Towmax, and Goodyear Marathon. NOTE: He has no real preference one over the other.
He is very keen on insuring the tires are sized, maintained and loaded properly. Like many have said on this and other forums, many of the tire issues fall squarely on the consumer for not taking care of the tires (proper loading, load balancing, tire pressure, proper speeds, etc). But, he also agrees with us in that many of the brands made off shore which are not strictly regulated by a reputable Brand (ie Goodyear, Power King, Maxiss) are not worth running on an off road farm trailer. He has seen what he says are way too many roadside service calls in which he knew the almost new "x brand" tires were used properly and the tires failed. This guy knows his tires, and if there's anything left of the failed tire, can tell you pretty much what caused the tire to fail.
Finally, I'm a business man and I fully understand how challenging it is to run a profitable business in today's world. I also understand cutting corners anywhere you can to reduce costs. But, the RV industry has an obligation not to cut corners on tires, wheels and suspension. These items should not be skimped on in the name of profit and put people's lives in danger. OK, that's my editorial comment. Thanks again Chris!!
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
cat, fifth wheel, forest river, maxxis, tires, upgrade, wheel, wildcat
