05-03-2014, 11:13 PM
#101
Not sure if it has been mentioned, but it seems most units with outdoor kitchens don't have a way of powering the refrigerator without shore power.
I would love a way of powering it while towing.
I can see a few ways this could be done...
- 110v/12v fridge (maybe not possible without doing an RV ammonia fridge?)
- provide an inverter to power the fridge (and potentially more!)
I would even settle for some pre-wiring that would easily facilitate installing my own inverter. Perhaps a 110V sub-panel in the compartment with the 12V batteries where an inverter and transfer switch could go later.
An inverter, or inverter pre-wiring, could be another dry camping selling point as well...
--Paul
05-07-2014, 03:37 PM
#102
Commercial Member
LT type tires with at least 15% more capacity that the GAWR and a TPMS for the TT.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
05-12-2014, 06:24 PM
#103
Magnets for all drawers. More head space over the sinks.
05-12-2014, 07:12 PM
#104
Boondocker package.
#4 awg wire from roof to best compartment for solar controller or conduit capable of this size wire.
Clearly defined roof joists for mounting rails for solar panels.
Magnum inverter pre-wire for ME-ARC remote panel.
Provision for at least 2 golf cart 6 volt true deep cycle batteries.
Conduits for running massive cables from solar controller to batteries and inverter to batteries.
AC sub panel for all receptacles and microwave and conduit for AC wiring to/from inverter.
Rear bumper shelf stout enough for a portable inverter generator and some 5 gallon gas cans.
No need to install the components, just prep for them. The hardest part when converting a rig for true camping is infrastructure.
Larger fresh water tank.
-Jeff
05-12-2014, 07:26 PM
#105
--Paul
I've wondered about a main frig that could rotate from inside kitchen to the outside kitchen like some TVs rotate from living to bedroom.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
05-12-2014, 09:56 PM
#106
Larger fresh water tanks. 100 Gallon gray water capacity and only 50 gallons of fresh water??
2010 Wildcat 30LOFT
2011 RAM 3500 CCLB Cummins
05-15-2014, 12:00 PM
#107
12 volt lights in closet and under sink.
2013 32rk sterling
05-15-2014, 05:56 PM
#108
Got them in the closet.
05-15-2014, 06:34 PM
#109
More lights in closets and storage areas and a small directional light over control panel
Tennessee
2014 Rockwood Mini Lite 2504s
2006 Ford Expedition
05-15-2014, 07:00 PM
#110
Looks like most ideas was covered but I have a few on the sewer/gray dump.
1. If you have tanks up front mid and rear pipe them together so you have a single dump point and want need a Y-fitting when dumping.
2. Install a clear PVC pipe at the last section so you can see what is dumping without having to add an aftermarket clear fitting.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
05-20-2014, 09:55 AM
#111
I would say a simple light wall switch as you enter the bedrooms ours does not have this. It has three double lights in the bedroom but not quick wall switch...like say, the bathroom.
Also dimmable his and hers reading lights above bed.
05-31-2014, 05:00 PM
#112
The best option that should be standard is the auto level.
05-31-2014, 05:36 PM
#113
How about a water hose connection that goes straight to the black tank without restriction? I hear a lot about folks that fill and drain their black tanks several times while dumping. Through the toilet valve takes a long time, the sprayer is longer.
But a straight in 1/2" hose fitting would fill it much faster. Of course you certainly wouldn't want to walk away from that.
05-31-2014, 06:18 PM
#114
Cyber Phrenologist
A few ideas, random order...
Turn signals amidships on each side. Bright ones, too! People get in a spot back there and can't see my trucks signals so they just ride along for miles... should be standard on all FR products over 25ft.
LEDs imbedded into light switches so I can find them in the dark. But not very bright, as all those lights would be annoying. Just enough to find the switch.
On "lesser" units like mine, extra stabilizer jacks near the axles. Crank downs for lesser units, electric option for higher end.
Option for 12 VDC outlets. Sometimes we boondock, and there is a world of 12 volt stuff out there I can't use for want of a place to plug it in. Had to make one up myself for my 5th wheel.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
06-12-2014, 07:53 PM
#115
The one thing I would love to see from Forest River is Owners Manuals specific to each model withlots of pics and detailed options list with pics. And more specific model info on the web site, like the saq365 sierra 5 pics that's it, I have to go to dealer web sites to specific items when looking for answers to my next purchase. I try to upgrade every 3 years, and spend hours and hours looking for specific pics and info.
06-12-2014, 09:37 PM
#116
Most needed upgrade in today's fifth wheels...
Um, our Rockwood has a tank rinser for the black tank - hook up a hose at the dump or your site, open the black tank valve, turn on the hose and you can hear some sore of rotary spinner spraying the black tank - cool addition Forest River!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
06-12-2014, 09:53 PM
#117
Location: Alberta - East of the Rockies, West of the Rest
Radio,
I like the idea of midship turn signals, excellent point. I have to take a look at ours but it shouldn't be to hard to add.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
#118
Um, so does mine.
No sprayer. Same water flow rate as putting a water hose down the toilet.
I hear guys talk about dumping, filling, dumping, filling, dumping, repeat. Water through the toilet takes forever to fill it and through the sprayer would take longer. In fact my first weekend out I pulled up to the dual sided dump station and I believe a guy was doing that. Letting it fill through the toilet. He was there two campers before me and was still there when I dumped and left.
So a connection with a check valve that runs straight to the top of the tank. Would greatly speed up filling for a rinse dump.
06-12-2014, 09:54 PM
#119
How about an interior design that's not stuck in the 80s.
Ordered: 2021....
06-12-2014, 10:12 PM
#120
Um, so does mine.
You can only fill as fast as the restrictions in the hose allow. I usually don't have much problems filling my tanks. If I close my black valve while dumping the gray it's about 1/2 full by the time my full grey fully dumps.
What I would like instead is a better sprayer. The black tank flush rarely gets it all and what takes time is having to let it fill in the first place. If the sprayer were positioned to help drive the leftovers towards the drain, then we might not even have to fill at all.
