Old 03-25-2018, 05:57 AM   #1
Unhappy Need help with my electric fireplace, please
Hello to you all,
Having problem turning my electric furnace on and off. It seems the switch doesn't click on or off, so I am presuming I have to change the switch. But my big problem is how do I access the switch? How can I get the front panel off? I would really appreciate someones help. Thank you so much in advance.
Pierre C. is offline   Reply With Quote
Old 03-25-2018, 06:10 AM   #2
Mr. Dan's Avatar
What year and model Wildcat has an electric furnace controlled by a clicking switch? My Wildcat has a propane furnace controlled by a thermostat? Experts here will need more information.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 03-25-2018, 06:15 AM   #3
So sorry, I didn't explain myself very well. Actually it is the electric fireplace I was talking about.
It is a 2012 Wildcat 313RE
Old 03-25-2018, 08:31 AM   #4
Mr. Dan's Avatar
Have you reset the furnace breaker in your electrical panel?
Does your unit have a remote control you can try? If so, fresh batteries?
Old 03-25-2018, 09:36 AM   #5
Thank you for your reply. I have reset the furnace breaker, but nothing happens. I have a remote, but I think the batterie is dead, have never used it. Will replace it today. But I still think it is the switch. There is no click when you turn it on or off. Doesn't seem like there is contact being made.
Changing the switch doesn't seem like it would be a complicated job, but still can't figure out how to access it. The whole panel has tv and furnace all in one piece, and don't really want to disassemble everything to get to the switch.
All help is really, really appreciated.
Old 03-25-2018, 09:38 AM   #6
CC75's Avatar
Hold the switch down for a couple of seconds. Seems that my electric fireplace does not come on instantly either. Other than that it has been working great.
CC75 is offline   Reply With Quote
Old 03-25-2018, 10:08 AM   #7
Ok, tried holding the switch for a couple of seconds and still not working. Have also tried to reset main breaker, again no luck. It was working great until about two weeks ago.
Old 03-25-2018, 01:22 PM   #8
Fireplace
My fireplace quit working last year. The outside frame slides up for removal. Then there were a couple of screws holding the fireplace box in place. Removed the screws and the box slid out. The fireplace actually plugged into an outlet behind the wall. When I plugged it into another outlet it worked perfectly. When I took it to dealer they plugged it back into it's original outlet and it worked. Go figure!
mikej248 is offline   Reply With Quote
Old 03-25-2018, 01:52 PM   #9
bikendan's Avatar
Titled edited from furnace to fireplace
Equalizer WDH
Old 03-26-2018, 07:56 AM   #10
cavie's Avatar
the OP has stated that the switch as gone from CLICKING to NOT clicking. Pretty much tells me the switch is broken. Moving the switch position to on and holding it down will not make it work. He is asking for advice as to how to access the now non-working switch.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-26-2018, 11:17 AM   #11
That is exactly what I need to know. How to access the switch. Thank you
Old 03-26-2018, 11:25 AM   #12
llr
Mine has a trim board over the top that you remove then the is an upside down U shaped metal trim that slides up and pulls out. then the 4 screws that actually hold the fireplace are exposed.
no idea if yours will be the same but probably similer at least
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 03-26-2018, 11:39 AM   #13
cavie's Avatar
A picture would help.
Old 03-26-2018, 05:44 PM   #14
Yes a picture will be greatly appreciated. Thank you
Old 03-27-2018, 03:49 AM   #15
cavie's Avatar
Yo, Pierre, We need a picture from you. Find your remote and replace the batteries. It SHOULD work fine.
Old 03-29-2018, 08:23 AM   #16
Hello again,
I replaced the battery from the remote, no success there. Here is a photo of my fireplace. Hope it is helpful. Thanks Sorry photo is upside down. I will try and correct this.
Old 04-01-2018, 07:52 PM   #17
First turn off the breaker to it.
Now look for screws that hold the entire fireplace in its position. They may be down at the floor or into the side of the trim. Basically they make a box that the FP slides into and then is screwed into place. Once you pull the FP from this box you should be able to see the back of it and find some access to the switches. Look for pieces of trim around it that can be removed and the mounting hardware might be under that.
Parrott_head is offline   Reply With Quote
Old 04-01-2018, 08:12 PM   #18
Pierre:
You should also provide any info you can on the make/model of the fireplace. You might not be able to tell the model number until you get the front cover off, but the remote control should at least state the makers name on it. That may help someone with the same make/model help you.
Knowing the make/model of your RV doesn't always help as the manufacturers swap component suppliers all the time.
I'm also assuming you don't have a owners manual for it?
2011 Traverse LT, 3.6L, FWD
Old 04-01-2018, 08:14 PM   #19
Just as confused as you
Scrapper's Avatar
The switch on my fireplace doesn't click loud enough to hear it unless it's dead quiet. The power for my fireplace is on the same breaker as the microwave. If I'm using the fireplace then turn on the microwave a relay turns off the fireplace. Does your microwave work?
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
electric, furnace
