Old 06-02-2018, 10:32 AM   #1
New 2018 Wildcat 383MB
Just had it delivered and in driveway. Issues so far; inverter will not shut off; while on battery inverter power the fridge does not work (no gas option); the battery disconnect does not seem to do anything?; electronic and manuals from Forest River are mostly worthless. Any help on operation or finding documentation would be appreciated.
Padgettra is offline   Reply With Quote
Old 06-02-2018, 11:24 AM   #2
AUHunter's Avatar
Sorry but I would be dragging it back to the dealer. The unit should have never been delivered and the issue should have been found with a good PDI. Did the dealer even do a walk-through with you?
AUHunter is offline   Reply With Quote
Old 06-03-2018, 07:25 AM   #3
Yes, dealer had technicians do a walk thru and pointed out items. Yet, when it is all hooked up in the shop bay everything looks fine. I removed the battery disconnect switch and it is bad(shorted). The inverter issue was the switchology on the inverter for the switch had to be in correct mode. Fridge works on shore power so will have to go on battery again and check it. The TV was not connected correctly so we had to figure that out to watch a movie. All in all not very happy, plus I called the dealership twice and they have yet to have technician call me back. Today we are going to put some water in the tanks and start looking at the plumbing and functional check that stuff. Thanks for the reply and the dealership will have to step up.
cat, wildcat
