03-24-2013, 07:59 PM
New 344QB problems
We just had our first camping trip in our new 2013 344. We had a few problems. The most major is the black water stop valve came out as did all of the black water when I went to dump the tank. A black disc came out with a small hole int the center of it (for screw I suppose). I got covered with black water, not happy. Also the upstairs vents dont blow anything with the furnace on, and the bunkhouse was freezing as the AC unit fan turns on when you turn on the furnace with no ability to turn it off. A big camping trip coming up and need at least a quick fix for the black water problem. Need help fast!
2013 Ford F-350, FX4 ,Long Bed, 6.7 Diesel, 11500# GVW package, camper package, plow package, Electronic locking 3.73 rear end.
Husky 16K slider hitch.
New Trailer 2013 Wildcat 344QB Touring Edition with angled master bed.
03-24-2013, 08:22 PM
The black disk that came out with the black water is the cut-out when they plumbed the tank. They should have removed it but obviously didn't.
The upstairs heats vents are probably the longest duct run from the furnace and therefore, have the least amount of flow. It's good to check where you can to ensure that the flexible duct isn't kinked, disconnected...should be able to see it in the basement. Some people have added register covers that can be partially closed to force more flow to another outlet.
If the AC fan is running when the furnace is on, you must have the fan selector set to 'on' instead of 'auto'.
03-24-2013, 09:20 PM
Thank you so much for the reply. I will check all in the AM. As for the fan, the thermostat is digital. How would I set the fan?
03-24-2013, 09:35 PM
Always Learning
Why kind of thermostat is it?
03-24-2013, 09:36 PM
cycle through to fan, and then use the down buttons to change the setting to auto. Then switch back to heat and set your temp.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
03-24-2013, 09:37 PM
Push the center mode button until it says fan than push the up or down button till it says Au than push mode button.
03-24-2013, 10:43 PM
It worked thank you all so much!!!
03-31-2013, 10:43 PM
The rear blackwater tank won't close but the front one is closed. Broken cable or valve?
03-31-2013, 10:49 PM
just like mine... hold a lighter flame next to the vent and almost nothing. dealer scope the vents and said all good ..NOT...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
03-31-2013, 10:51 PM
Any problems with one of the black water tanks not closing off?
04-01-2013, 05:12 AM
Commercial Member
Don't mean to sound like a dumb question, but is there another dump valve somewhere?
You should have a separate pull valve for each tank...
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
04-01-2013, 09:06 AM
Right side between the slides hidden up under the skirt
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
04-01-2013, 09:33 AM
Wow thank you so much! The dealer nevet showed me that . I just called them and they didn't know about it. Second time this forum has helped when the dealer couldn't.
04-01-2013, 09:42 AM
My sales man was great but the prep guy knew nothing, since they cost more then 35k they should know
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
04-01-2013, 09:55 AM
Green, if you hunt Blackwater I might see u this fall as I travel down to hunt sika. When we lived in st.marys county, (ridge) traveled over a lot in the 18 years to hunt them
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
04-01-2013, 10:17 AM
I don't hunt them, my neighbor does however
04-23-2013, 10:24 PM
Sorry to hear about your black water issue. I had some valve issues too. May I suggest the Valterra T58 twist on valve? It twists on your drain and provides an extra back up valve to help prevent spills when hooking up/dumping. It could also help until you can get it in for repairs.
