Old 03-24-2013, 07:59 PM   #1
Greenshield's Avatar
New 344QB problems
We just had our first camping trip in our new 2013 344. We had a few problems. The most major is the black water stop valve came out as did all of the black water when I went to dump the tank. A black disc came out with a small hole int the center of it (for screw I suppose). I got covered with black water, not happy. Also the upstairs vents dont blow anything with the furnace on, and the bunkhouse was freezing as the AC unit fan turns on when you turn on the furnace with no ability to turn it off. A big camping trip coming up and need at least a quick fix for the black water problem. Need help fast!
2013 Ford F-350, FX4 ,Long Bed, 6.7 Diesel, 11500# GVW package, camper package, plow package, Electronic locking 3.73 rear end.
Husky 16K slider hitch.
New Trailer 2013 Wildcat 344QB Touring Edition with angled master bed.
Greenshield is offline   Reply With Quote
Old 03-24-2013, 08:22 PM   #2
Dave_Monica's Avatar
The black disk that came out with the black water is the cut-out when they plumbed the tank. They should have removed it but obviously didn't.
The upstairs heats vents are probably the longest duct run from the furnace and therefore, have the least amount of flow. It's good to check where you can to ensure that the flexible duct isn't kinked, disconnected...should be able to see it in the basement. Some people have added register covers that can be partially closed to force more flow to another outlet.
If the AC fan is running when the furnace is on, you must have the fan selector set to 'on' instead of 'auto'.
Old 03-24-2013, 09:20 PM   #3
Thank you so much for the reply. I will check all in the AM. As for the fan, the thermostat is digital. How would I set the fan?
Old 03-24-2013, 09:35 PM   #4
Fulltime family RVer
Why kind of thermostat is it?
Old 03-24-2013, 09:36 PM   #5
jtstromsburg's Avatar
cycle through to fan, and then use the down buttons to change the setting to auto. Then switch back to heat and set your temp.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-24-2013, 09:37 PM   #6
67redbowtie's Avatar
Push the center mode button until it says fan than push the up or down button till it says Au than push mode button.
67redbowtie is offline   Reply With Quote
Old 03-24-2013, 10:43 PM   #7
It worked thank you all so much!!!
Old 03-31-2013, 10:43 PM   #8
The rear blackwater tank won't close but the front one is closed. Broken cable or valve?
Old 03-31-2013, 10:49 PM   #9
jevanb's Avatar
just like mine... hold a lighter flame next to the vent and almost nothing. dealer scope the vents and said all good ..NOT...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 03-31-2013, 10:51 PM   #10
Any problems with one of the black water tanks not closing off?
