Old 02-06-2012, 01:01 PM   #11
NorminN.B.'s Avatar
Hey, Chris, u wouldn't have an online brochure for a 09 Cherokee 39L, would you. Thanks, NorminN.B.
NorminN.B. is offline   Reply With Quote
Old 02-06-2012, 02:56 PM   #12
bikendan's Avatar
by simply Googling "2009 Forest River Cherokee brochure", i found it right at the top.
and remember, Chris works for a different division.
we need to allow him to focus on Wildcat owners and not other brands/divisions.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-06-2012, 03:17 PM   #13
NorminN.B.'s Avatar
Thanks, Bikendan. I should have said it was a 2008 instead of 2009. Still haven't found one yet. You would think 09 was close, but it doesn't seem to be. Mine was built in March 08, but is registered as 09. I don't know why Forest River can't archive their brochures.
Old 02-06-2012, 07:36 PM   #14
bikendan's Avatar
the '09 should be close to the '08 though.
good luck to you, i found another post for someone also looking for an '08 Cherokee brochure and he got no responses.
Old 02-06-2012, 11:04 PM   #15
Dave_Monica's Avatar
Originally Posted by Wildcat Chris View Post
None of them? The eXtraLite series ranges in weights from 6,485 lbs. to 8,510 lbs. at the heaviest. While I understand there's frequently debate on these forums about weights, please check the specs and the tow vehicle ratings for more info.
You're pointing out the dry, towing weight...the issue isn't that...its the pin weight that a 1/2 ton truck can carry. The listed dry pin weights for the eXtralite is 1440 lb and up. You can add another 300 to 400 lbs when loaded, ready to camp.
Outside of the Ford 1/2 ton with the max payload pkge (GVWR 8200 lbs), there isn't a 1/2 ton that can carry a 1800 lb pin weight and not exceed the rear axle weight rating.
I used to tow our Rockwood 8280WS with a Ram 1500, but the loaded pin weight on it is only 1240 lbs...that put me just under the axle weight rating of the truck...that with two of us, a 80 lb dog and full fuel.
Don't see how you (and other manufacturer's) can claim that 5th wheels with this kind of pin weight are 1/2 ton towable.
Dave
Old 02-07-2012, 10:42 AM   #16
JAYCO Representative
Wildcat Chris's Avatar
Exclamation Match your tow vehicle and trailer appropriately!
I appreciate what you're saying (my advice to all potential Wildcat owners has always been "you want more truck than trailer"), but there are indeed new "heavy" half ton trucks (like the Ford you mention) that can handle our fifths. The eXtraLite series includes half-ton towable travel trailers as well. In any case, it's important to match your tow vehicle and trailer appropriately!
Again, it's always best practice to check all weights and specs before pairing a tow vehicle to an RV. Here's some helpful links:
Trailer Towing Guides | Trailer Life Magazine (Updated with 2012 info)
FORD: http://www.ford.com/resources/ford/g..._F150nov18.pdf
CHEVY: http://www.chevrolet.com/assets/pdf/...ring_Guide.pdf
DODGE: Dodge Towing Guide - By Load Weight
Wildcat Chris is offline   Reply With Quote
Old 02-07-2012, 11:41 AM   #17
Chris, I agree whole-heartedly in matching the tow vehicle and camper appropriately...that's why I have trouble with the advertising of the eXtralite 5th wheels as 'half ton' towable given their pin weights and that their GVWR is over all truck manufacturers' ratings...Ford has the highest rating at 11,300 lbs.
It's interesting that in the Wildcat brochure on pg 13 where it claims the eXtralite line as 'half ton towable', the picture shows a 293REX being towed by a Silverado 2500HD.
Hmmmm...
Yes, there are some 1/2 ton towable 5th wheels out there, but very few if you hold the truck manufacturer's rating near and dear. Usually the truck's GVWR and/or GCWR will be exceeded.
Dave
Old 02-07-2012, 08:31 PM   #18
hatstomper's Avatar
Hmmmm...
Dave
Hi Dave. Which Ford has a GVWR of 11,300???
Jim
2011 Chev 3500HD LTZ Duramax
2013 Sterling 32RK
Hijacker double pivot slider
hatstomper is offline   Reply With Quote
Old 02-07-2012, 08:41 PM   #19
The GVWR is reference to the Wildcat eXtralite campers max weight.
The 11,300 lbs is the maximum towing capacity weight for the F150 with the max tow package.
Sorry for the confusion.
Dave
Old 02-07-2012, 08:46 PM   #20
hatstomper's Avatar
Dave
I was thinking I bought the wrong truck!. My GVWR is 11,500, phew...
Jim
2013 Sterling 32RK
extralite, forest river, led, sterling, wildcat
