Old 07-15-2016, 10:00 AM   #1
Newbie 2014 Wildcat 327CK
4th RV here. Only issue I currently have is no DC power unplugged except slideouts. Any ideas?
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 07-15-2016, 10:05 AM   #2
SeaDog's Avatar
If the slides are working and you are unplugged and no other 12V I would check the lead to the controller for a fuse or disconnect. Test at the controller to see if 12v is there.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 07-15-2016, 10:10 AM   #3
TURBS's Avatar
Battery disconnect off?
The slides and landing gear are wired direct to battery .
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-15-2016, 10:13 AM   #4
Controller?
Old 07-15-2016, 10:19 AM   #5
SeaDog's Avatar
Too much coffee I meant converter stuff happens
Retired Navy
AF&AM of Idaho
Old 07-15-2016, 10:20 AM   #6
Is it behind the fuse box?
Old 07-15-2016, 10:31 AM   #7
2015 Columbus 320RS
2008 2500HD Duramax
X2
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 07-15-2016, 10:37 AM   #8
SeaDog's Avatar
If you have 12V while plugged in and none when not on shore power check for a disconnect switch more then likely up by your battery. Mine is under the propane tanks on the forward tongue in the vertical position it is off and horizontal on
Retired Navy
AF&AM of Idaho
Old 07-15-2016, 10:55 AM   #9
Did not find a switch, but did find a very loose wire on the connection panel by the batteires. Thanks, I will check it after takedown on Monday.
Old 10-22-2016, 08:10 PM   #10
RwWildcat327re
rickndebi's Avatar
Did u find your switch?
rickndebi is offline   Reply With Quote
2014, cat, newbie, wildcat
