Old 07-25-2016, 10:10 AM   #1
No 12volt Unplugged
Recently purchased a 2014 Wildcat 327CK. The 12 volt only works when plugged in. Slides and hydraulic legs work. I understand there is a switch that can turn off. Anyone know where it is?
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 07-25-2016, 10:13 AM   #2
On my Micro Lite, the battery disconnect switch is under the gas bottles.
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 07-25-2016, 10:20 AM   #3
Already looked there.
Old 07-31-2016, 09:12 AM   #4
My disconnect is in the top right hand corner in out side shower area.
Steve29rlx is offline   Reply With Quote
Old 07-31-2016, 09:44 AM   #5
I found a circuit tripped by battery.tiny black button on left of third connection from top.
Old 07-31-2016, 09:46 AM   #6
Seasoned Rookie
Lefty59's Avatar
Our battery disconnect switch is in the basement on the street side, high on the right side back wall next to the water service panel. It's a spring loaded handle that hangs on a cord when in the disconnected state. To connect, insert the handle and turn.
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 07-31-2016, 02:25 PM   #7
Moderators' Assistant
bikendan's Avatar
yep, that's a resettable fuse that usually trips when the battery gets hooked up backwards.
happens a lot when owners are reinstalling the battery and get the wires backwards.
not saying that you did this, just that this is the most common cause.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 08-01-2016, 07:08 AM   #8
jonrjen's Avatar
I have to disagree as the this being the most common cause of tripping this fuse. I firmly feel that the most often cause is RV Gremlins. They do it just to mess with us.
jonrjen is offline   Reply With Quote
