Old 06-13-2016, 11:45 PM   #1
duradiesel's Avatar
No power 120 outlets
We were dry camping last weekend using solar panels to keep the batteries charged . We were going to use the microwave on generator power but no outlets had power . All the breakers are set . . I ran an extension cord in & plugged the microwave in; i worked just fine . Plugged in at home everything is fine. I have installed a P.I. 50 amp hard wired protector in. Could it be the ground that's the problem? The battery's were charging off the generator.
2006 GMC Duramax Extcab LB
2012 Wildcat Sterling 32RL
duradiesel is offline   Reply With Quote
Old 06-14-2016, 01:44 AM   #2
wmtire's Avatar
There are several things here that could be wrong.....especially since you have a 50 amp RV (which has two hot legs L1 and L2), plugged into a generator. We need a little more information to really ascertain where the problem could be.
First off, what generator are you using and how did you connect to it (ie what connection on the generator did you plug into and if/did you use some kind of adapter)
Did you notice an error code on your Progressive Industries protector when connected to the generator, and if so, what was the error code. The PI protector will shut off electricity to your RV if certain conditions exist in your connection to the generator.
I'm also confused a little by what I emboldened in blue above, as this seems to me to be a contradiction.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-14-2016, 06:15 AM   #3
RSchleder's Avatar
I agree, a bit short on info here. The one thing I would suggest is checking is the breaker on the generate itself.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 06-15-2016, 09:03 PM   #4
duradiesel's Avatar
I have a Champion 2000 watt gen set. yes I have a 50 amp cord reduced down to 15 anp plug. I didn't see a error code . I will try it at home on the weekend & check it then.
Old 06-15-2016, 09:27 PM   #5
Bluepill's Avatar
A plug-in outlet tester is very helpful, although not 100% true in all cases. Available for about 5 bucks at home centers, etc.
2008 Itasca Meridian 37H
Old 06-15-2016, 09:28 PM   #6
Your Champion generator has an open neutral and your P.I. EMS has detected this and is trying to protect your RV. You need to bond the neutral and ground in order for it to work. The link below does a good job of explaining this. I heard (but don't know for sure) that Yamaha generators can not be bonded in this manner. I do know that it can be done on Honda generators.
http://noshockzone.org/generator-gro...utral-bonding/
tkarper14 is offline   Reply With Quote
Old 06-15-2016, 09:51 PM   #7
wmtire's Avatar
Sorry it took me so long to see your reply, but it appears tkarper14 has you fixed up, with a great explanation and link.
You can go to Progressive Industries website and download a user manual for your particular hard wired protector that also touches on the generator bonding plug as I copied this from one of their users manuals there. I think you may also have a switch to be able to bypass your protector....but don't quote me on that.
Old 06-15-2016, 09:55 PM   #8
wmtire's Avatar
Mike also has a great youtube video here using a progressive industries EMS:
Old 06-16-2016, 12:01 AM   #9
duradiesel's Avatar
Smile
Thanks everyone for the good information . I will make a plug this weekend & try it.
Old 06-16-2016, 07:40 PM   #10
mikes86gn's Avatar
Just my 2 cents. I thought that a 50 amp plug was 240 volts. 120 volts on two separate legs to ground. When adapting to a 15 amp plug you have eliminated one leg of 120 volts. I believe one leg is for one air conditioner and the other leg is for the other air conditioner and the rest of the unit.
Mike
2012 Silverado 2500HD 6.0 Gas 4.10 gears
1986 Buick Grand National 4500 Actual Miles
2015 Crusader 28RL
Days camped 2014 33 . 2015 42. 2016 38. 2017 35.
mikes86gn is offline   Reply With Quote
power, electrical
