Old 07-20-2017, 05:53 PM   #1
cavie's Avatar
oven temp
Oven won't go over 275. Any ideas? Magic Chief
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 07-20-2017, 09:18 PM   #2
Iwannacamp's Avatar
oven temp
I started to post earlier and didn't. Here I go...
I assume the dial/knob will go higher?
I assume it used to work?
I assume you haven't serviced the LPG system in any way?
So to me that means you aren't getting enough pressure. I.E. bad regulator or trash in system. Might turn off both bottles and purge lp gas as lit burner. Then slowly open tank valve again. Prolly won't fix, but it's an easy cheap fix.
Then I would go to or call your local LP service company and talk to them about checking or repair.
I guess it could be the thermostat or gas valve too. I assume if the gas valve works its good.
2017 Puma 297RLSS
Old 07-20-2017, 10:05 PM   #3
cavie's Avatar
Yes to all your assumptions. I'll give it a try. My rig is in a permanent camp where we stay in for 4 months a year in Western MA. Worked when we left last year. Thanks for the responce.
Old 07-21-2017, 12:00 AM   #4
Iwannacamp's Avatar
No problem. Hope you figure it out.
2017 Puma 297RLSS
