Old 06-06-2017, 12:30 PM   #1
Paging wildcat steve
Need some advice/help on a tire question. New 2017 F350 dually. Truck is about 2 inches taller. Camper is a 15 Wildcat 333MK. While not a big difference, I may look into going from 235-80R-16 to 235-85R16. Use the same rim, that is not a issue. I do not want to adjust the pin box or 5th wheel hitch in height because I am 6.5 inches from the bottom of the camper to the top of the truck.
1. What tires in that size does the factory use if they use that size (ST235-85R-16) at all.
2. Or, do you suggest I just move to 17 inch tires from 16?
Frank1 is offline   Reply With Quote
Old 06-07-2017, 12:45 PM   #2
Well, found the answer. The HiSpec rims that came on my 2015 333MK are rated at 200 psi with the metal valve stem. That is straight from HiSpec. I can safely use ST235-85R-16 F on my camper. Rated @ 80 PSI. So I guess since the Goodyear Endurance is selling like hotcakes and is being used on a myriad of campers, that is what I shall use!
wildcat, cat
