Old 09-30-2016, 09:06 AM   #1
Question Playing TV through Genesis 2.0 stereo
New to me, 2010 28RKBS. Something has me perplexed. I can't for the life of me get my TV to play through the on-board speakers through the Genesis 2.0 stereo - which by the way I hear is crap. The TV has RCA plugs exiting the TV and going into wall behind it. What am I doing wrong?
Thanks in advance.
KJ
2010 Wildcat 28RKBS (purchased March 2016)
Pullrite #2700 Superslider
2006 Dodge Ram 2500 2X2 diesel
2016 - 41 days (2,800 miles)
kejorgensen is offline   Reply With Quote
Old 09-30-2016, 09:53 AM   #2
raspivey's Avatar
Make sure the radio is set to AV1 (which looks a lot like AU1...not the same thing).
Old 09-30-2016, 10:19 AM   #3
Pull the unit
FYI. My Genesis 2 has been very good to me. Hope that does't jinx me. Anyway pull off the front bezel, be careful as it just snaps into place and the tabs can break. I think it is held in place with six screws. See where the RCA cables go. I believe I used an optical audio cable as that input was available. I have no problem pumping my TV through the unit. You might have to also select either "fixed" or "variable" audio out on the TV. I have to turn my TV sound down all the way to use the Genesis as the volumes are out of sync. NOT MUTE, just volume to Zero. Takes some playing with. I think my audio out was connected to "AUX 2" I think I connected my optical to "AUX1". It has been a while
Good luck
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
