Old 07-10-2016, 08:47 AM   #1
Freedom2016's Avatar
Portable black water totes
We are looking into buying a portable black water tote so we can empty out tanks when we do not have sewer connection at the site. Any suggestions? How about storage when in transit?
Freedom2016 is offline   Reply With Quote
Old 07-10-2016, 09:14 AM   #2
We carry ours in front of the hitch in the truck bed.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 07-10-2016, 09:22 AM   #3
Who Dares, Wins
doc73's Avatar
Had a barker, worked well until we got a bigger trailer with larger tanks. I now have. Thetford one which also works well. I have only used them for grey water but I always try to get one the same size or close to the tanks I am dumping to avoid an overflow situation.. I store it in the truck bed or on the rear bumpers cargo carrier.
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 07-10-2016, 09:23 AM   #4
fonzie's Avatar
Carrying Barker Tote on Ladder
Fonzie
Old 07-10-2016, 01:04 PM   #5
Use a 27 gal Therford for gray water only. I cradle it horizontally in one of the brackets used for transporting ladders or lawn chairs on the RV ladder. Fits perfectly. Larger ones may not fit the bracket. Secure it with two ratcheting straps- one horizontal the other vertical. I remove the cap on the portable unit so the sun don t expand the heated air in side. Only take it when planning trips to state parks ect with out sewer connections
twoclaws is offline   Reply With Quote
Old 07-10-2016, 01:19 PM   #6
Coolharts's Avatar
I have a 32 gallon tote for grey water only, my black tank can go for a whole week without being emptied. I either carry it on by back rack if I do not have bikes or I carry it on the front, behind the LP tanks over the battery boxes. With the Puma it fit in the front compartment, won't fit in the Surveyor. When you have an SUV you have to be creative.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
Nights Camped 2018 4 Scheduled 25 (so Far)
Coolharts is offline   Reply With Quote
Old 07-10-2016, 01:26 PM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
I carry mine in the bed of my pick up. Very seldom use as only two of us. When I know I'm staying at sites with full hook ups then I leave at home. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-10-2016, 01:29 PM   #8
djemgoss's Avatar
I have a 32 gallon Barker that I have only used for gray water! Gray water is always near full after two or three day! Black water is well over a week to get full. I carry it in the back of my pick-up and hook it to the hitch ball and pull it to the dump station to empty. then put it back into the truck box.
Dave & Elaine
Brookfield, WI
2016 Rockwood, ROO 21SS, pulled by a 2015 F150 XT, Super Cab, 2.7L Eco Boost, with 3.55 axle. Electric 6-speed auto trans w/tow mod. Tow package & integrated trailer brake. 7,600 lb. tow capacity. 145 wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 07-10-2016, 02:00 PM   #9
Blog: RVroadtripper.com
hbillsmith's Avatar
I have the 32gal Barker that I carry in my front storage bin until I'm camping somewhere that I need it. Then it spends time either under the trailer or in the truck bed. By the way, my 32gal Barker was perfect when I had a TT with 30gal tanks, now I'm in a 5er with 50gal tanks. I have to be careful not to overflow the blue, something I've done once but thankfully it was grey not black that made the mess. I've had my eye on the new big 4 wheel Thetford2.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 07-10-2016, 02:09 PM   #10
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Get the biggest one your back can handle and you'll be glad with fewer trips. BTW......make sure you take your time to the dump-station when you're doing it. You go too fast and you'll be mad at yourself. Flush it out real well at the dump-station.
Grampa Jim is offline   Reply With Quote
black, black water, water
