Old 07-31-2017, 08:33 AM   #1
jeepman71's Avatar
Propane Regulator Question
Hi All,
I have a 2014 317RL. It has the automatic switch over regulator and it also has a smaller regulator on the second tank. This smaller regulator has failed me three or four times so I have replaced it. The new regulator has failed a couple of times as well. Like I said it has the main regulator, why do I need this second regulator on the one tank?
I see no reason to keep it so My question is is it necessary?
Jim, Julie and Rags the boss.
2015 Dodge CTD 3500 Bighorn pulling 2014 Wildcat 317RL. Life is good when spent with family and friends.
jeepman71 is offline   Reply With Quote
Old 07-31-2017, 10:24 AM   #2
Head Rambler
The regulator in the second cylinder side is to lower the pressure from LP vapor pressure (~175 PSIG @ 100ºF) to about 10 psi, so that high pressure isn't running through 10' of rubber hose from one side to the other.
Gotta go campin!
Old 07-31-2017, 10:28 AM   #3
jeepman71's Avatar
Thanks for the reply. Probably should keep it.
Old 08-12-2017, 06:40 AM   #4
cavie's Avatar
stopped using the second regulator 2years ago.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 08-12-2017, 08:52 AM   #5
Learjet's Avatar
It is a legal requirement (DOT ??) because of the rubber line and the length of the line pressure etc.
I had problems with mine, and it turned out to be the check valve on the passenger side main regulator. Hose comes across and goes into a check valve. you can remove check valve, just have to turn off both bottles if you remove the driver side bottle.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 08-13-2017, 07:01 AM   #6
onetonford's Avatar
The issue with it is that propane can condense in the cross over hose and when you close the valves on both tanks the pressure can build to bursting pressure of hose. The Regulator is put there to keep it below the condense pressure so no liquid can accumulate in the hose. Mine is a 18lb regulator if they use the wrong one it will fail they have several that look just like this one just make sure they are using the right one. also make sure it is installed in the right direction.
Name:	red regulator.jpg
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
propane
