Old 06-30-2013, 01:47 PM   #1
k52412's Avatar
Proper psi
What is the proper psi for the trailer tires. These tires are nitrogen filled can you mix with air? Thanks
k52412 is offline   Reply With Quote
Old 06-30-2013, 01:51 PM   #2
Simple thing to do is fill to max stamped on sidewall of tire and yes you can mix air with the nitrogen. Reg. air is 78% nitrogen, so you won't be jeopardizing your nitrogen by very much if you only add a few pounds.
Old 07-03-2013, 12:50 AM   #3
There should be a sticker on the outside of your unit that says what the psi is. Generally you want to run the max. If your tires are the original then running the max on the tire sidewall is also done.
goduc is offline   Reply With Quote
