Old 03-29-2012, 09:22 AM   #1
Rear stabilizer jacks stopped working
I have the electric rear stabilizer jacks on my '10 27BH FW. They worked find and the other day, they just stopped working. I have checked all my fuses and breakers and everything is fine.
I've been using the manual feature to crank them up and down.
I have removed the electric motor and inspected it and then replaced it and that looks fine.
Any thoughts on where I should begin? I'd like to do as much as I can before I bring it in to the shop.
twrv is offline   Reply With Quote
Old 03-29-2012, 09:47 AM   #2
Triathletedave's Avatar
I had the same problem with my Surveyor. Turns out there was an inline fuse that I was not informed about. Mine had the wrong fuse based on the electric motor, and had to be upgraded.
Ask your dealer about any inline fuses on your jacks.
Good luck!
Dave & Jill
2012 Ford F-150 EcoBoost
2012 Surveyor SV-294
2 kids, one dog (a Golden)
Let's go camping!
Triathletedave is offline   Reply With Quote
Old 03-29-2012, 10:44 AM   #3
Was it hidden somewhere. I've checked all of the exposed wiring and can find no in-line fuse. But the wiring goes into some concealled areas in the underbelly that I can't easily access.
Good luck!
Old 03-29-2012, 11:52 AM   #4
Bearcat55's Avatar
I recently had the same issue with my jacks, awning and slide. I searched forever and finally called a dealer and the told me there was a 20amp inline fuse behind the panel under the fridge. happened a couple more times so I replaced the fuse with a breaker.
2012 Salem 30KQBSS
2010 F150 S-Crew 4x4 5.4L
Bearcat55 is offline   Reply With Quote
Old 03-29-2012, 12:28 PM   #5
TURBS's Avatar
Did you infact check to see if you even had voltage to the jacks
I would think one would start there.
Old 03-29-2012, 12:50 PM   #6
I found mine while searching to having no water to outside sink in our 2012 Grey Wolf 28BHKS under the tub compartment.. Good Luck
germainesaint is offline   Reply With Quote
Old 03-29-2012, 01:19 PM   #7
Herk7769's Avatar
I would absolutely look here first.
HAM CALLSIGN - KC3FFW
Old 03-29-2012, 08:45 PM   #8
Not yet. Good idea.
Old 03-30-2012, 08:08 AM   #9
Inline fuse
It wasn't really hidden, just out of sight. My inline fuse was tucked up under the frame which made it harder to find, especially in the dark on a rainy night. I hope you have better luck!
Dave & Jill
Let's go camping!
Old 03-30-2012, 08:14 AM   #10
Herk7769's Avatar
Don't know about your camper but my rear electric stabilzer jacks were fused in the panel (yours could be behind the panel in an inline fuse holder) AND had a resetting fuse near the outside UP/DOWN switch.
Name:	Hidden circuit protection rear stabilizers.jpg
ID:	11460   Click image for larger version
Name:	913th 3rd Annual Picnic and Camper photos 034.jpg
